Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 11-03-2009, 11:04 PM   #1 (permalink)
fuel tank switch valve / fuel tank
I am in need of a new front fuel tank for my '97 Stroke. ford wants almost $500 bucks, no junk yard in my area has one, and welding a piece of steel to cover the hole doesn't sound real safe. Any ideas? I've checked Ebay and found nothing. I also need a fuel tank switching valve. Fuel is running from my rear tank into the front tank and then leaking out the hole. WOW!! Ford wants $185.20 for a new one and yes, it's a dealer only piece. I've checked with NAPA, Checkers, and even Ford said it's a dealer only piece. Any ideas or suggestions? Guess I could just bite the bullet and buy everything new, but that's a bunch of money I really don't have. Thanks.
skibrain is offline
Old 11-04-2009, 01:14 AM   #2 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
You are gonna have to bite the bullet on the switching valve. It will most likely be a one time investment considering the one on your truck now is most likely the original. You can get a new front tank from Autozone, Advance Auto, NAPA, O'Riellys, etc. Way cheaper than ford. Make sure the new tank is steel or plastic as the galvanized units have a reaction to diesel fuel for some reason.
97 F-350,4X4, CC, LWB, PSD, 251k, K&N, 10K MOD
speeddemon31176 is online now
Old 11-04-2009, 08:05 AM   #3 (permalink)
I bet Rockauto has the tank...maybe lmc truck too.
I think its a F6C. The ones made by Spectra will be good, they are ni-terne steel which is NOT the same as galvanized.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
Old 11-04-2009, 08:09 AM   #4 (permalink)
Yep, Rockauto has the tank, it is the F6C.
AND they show that they have the switching valve for around $85 I believe.
coming soon: 6.0 IC
