Glow plug relay test procedure - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 04-29-2006, 01:20 PM Thread Starter
Hello, I can't find the glow plug relay test procedure anywhere? Could someone put a link or put instructions please?
Thanks in advance for responses.
Corey Esson
2000, F350 Lariat, CC, Blue, At 110k miles (Oct 09) TRC Auto Trans, 4x4, Tymar Intake, Banks EGT, Tranny Temp and Boost A pillar gauges. Banks chipped, and exhausted. DIY LED Cab lights. 05 style Headlights. Marinco Mod
"When it's upsidedown and burning, you've gone too fast."
"Customer Service is an ATTITUDE!!...not a department!"
Corey Esson is offline
post #2 of 4 (permalink) Old 04-29-2006, 01:27 PM
Re: Glow plug relay test procedure
check both big terminals with a test light. with the key off only one has power. with the key on both should have power. if not you have a bad GPR.
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
post #3 of 4 (permalink) Old 04-29-2006, 01:33 PM Thread Starter
Thank you very much! I'll try this. I thought there was something to do with the small terminals as well but guess not?
Corey
post #4 of 4 (permalink) Old 04-29-2006, 01:41 PM
they are the power from the key and a ground I think but the big terminals are where you want to check. key on and key off.
krowell is offline
