got a problem - Diesel Forum - TheDieselStop.com
Old 12-06-2012, 09:52 PM   #1 (permalink)
got a problem
Got a 96 ford 250 crew cab short bed 4x4 diesel and I have got 265 75 16 on it and when I turn the wheel to the left the driver front tire hits the bumper but the other front tire doesn't do that and it only does it when u turn the wheel to the left though what could that be I don't want to blow a tire out please any idea will help thanks
cloudd21 is offline   Reply With Quote
Old 12-07-2012, 06:10 AM   #2 (permalink)
that is normal, I hac to put a pumper extender on my wifes truck.
1995 PSD F-350 4X4
97 motor installed.
DaveH. is offline   Reply With Quote
Old 12-07-2012, 08:14 AM   #3 (permalink)
Well ok where can I get one of them for my truck then ?
Old 12-07-2012, 05:01 PM   #4 (permalink)
I got mine at Les Schawb.
1995 PSD F-350 4X4
97 motor installed.
Old 12-07-2012, 05:07 PM   #5 (permalink)
bugman's Avatar
My Photos: (12)
A bunch of 1/2" washers will work just as well and anything that you buy. Also depending on how far out you want to move it you may need new longer bumper bolts.
bugman is offline   Reply With Quote
Old 12-09-2012, 10:34 AM   #6 (permalink)
1997fordman's Avatar
May be a dumb question but are your springs sagging at all? My old 97 was the same as yours and the truck sat level and the springs in front were pretty much straight.
Phil
97 F250HD SC SB PSD ZF 5SPD 4X4 OFF ROAD 230K CHROME GRILLE GUARD GOOSENECK WARN MANUAL HUBS LUK SMFW KIT FIRESTONE AIRSTROKE AIRBAGS OTHERWISE STOCK FOR NOW
SOLD FOR PAYOFF
NEW OLD TRUCK: 94 F250 SC LB POWERSTROKE ZF 5SPD 2WD 279K AND ROLLING LUK STYLE SMF KIT HERCULES REAR BUMPER NOTHING FANCY
1997fordman is online now   Reply With Quote
Old 12-09-2012, 12:42 PM   #7 (permalink)
That doesn't sound normal to me, not with 265/75s. They're actually about 1/10" SMALLER in diameter than the stock 235/85s. No way they should be hitting the bumper. How much clearance do you have on the other side when you turn the wheel?
madpogue is offline   Reply With Quote
Old 12-09-2012, 06:25 PM   #8 (permalink)
i had 305`s on mine for awhile. never rubbed
97 250extracab 4x4 stock, auto
dieselade is offline   Reply With Quote
Old 12-10-2012, 07:49 PM   #9 (permalink)
They're smaller but wider. I suspect the corners where the sidewalls meet the tread is what's rubbing. Again, I'd look at the front leaf springs and bushings.
Sent from my iPhone using AutoGuide.com Free App
SOLD FOR PAYOFF
Old 12-13-2012, 07:15 PM   #10 (permalink)
My leaf springs are sagging but the other side don't do it and the driver side like normal what do I need to look for
Old 12-13-2012, 09:25 PM   #11 (permalink)
I'd say start looking for new springs, if yours are sagging.
(You also need to look for your period and question mark keys, but I digress.....)
Old 12-14-2012, 12:13 PM   #12 (permalink)
alright were could i find a stock set of leaf springs though?
Old 12-14-2012, 01:07 PM   #13 (permalink)
bugman's Avatar
My Photos: (12)
The stock springs have a negative arch in them so they look like they are sagging. Check the distance between the bump stop and the spring pack. If it is less than a inch you may have spring sag. As for where to get new ones, good luck. Check around your area if you have a spring shop that could build them for you or re-arch the old ones. Also check your shocks. If they have over 50K miles on them they may need to be replaced.
Old 12-14-2012, 06:47 PM   #14 (permalink)
xwhatever on a spring problem. My '97 has had 265s on the stock wheels since about 20k miles and it has 198k on it now. They have never been close to rubbing. Anything bigger would be a problem, but not this size.
Snowtow is offline   Reply With Quote
Old 12-21-2012, 02:18 PM   #15 (permalink)
The off road package I think is different. My springs were straight with very little if any sag. If there is a heavy duty truck shop near you they may be able to re-arch them. If not maybe a set of helpers. Could also be TTB bushings or radius arm bushings or an alignment issue. Shimming the bumper is IMHO not a solution unless everything else checks out.
SOLD FOR PAYOFF
