gotta start automatic in neutral - Diesel Forum - TheDieselStop.com
Old 11-17-2009, 08:18 PM   #1 (permalink)
i gotta pull my truck down in neutrel to start it. it will start in park but it makes a funny sound very hard to explain like a loping or chugging sound. sounds like a race car motor with a monster cam in it. that only way i know how to explain it. i had one guy tell me it was a range sensor but i and some other guys i talked to have never heard of that. i even called ford asking price for part and they dont have such a part. can someone please help
ERIC
97 F-250 Red ext.cab long bed 4X4 junky slush box e4od 4.10 gears no muffler, new power steering pump, vaccum pump, fuel pump,water pump, fuel heater un plugged, k&n air filter, waste oil powered free fuel nothing like stickin it to the man 217,000 still running strong
67 F-100 Ranger 351 W auto my first truck
93 mazda b2600i auto 143,000
wifes ride 98 lincoln navigator
used to own:
01 F350 psd crew cab 4X4 junky e4od
f350powerstroke01 is offline
Old 11-17-2009, 09:45 PM   #2 (permalink)
S95
NSS, neutral safety switch located on the side of the trans. if that is it, it may soon not start in park or N. But then you can jump the fender solonoid as it bypasses that wire by using your best screwdriver.
do your PRND21 slots line up properly when selected? you can get slop in the linkage and that can be adjusted down beside the trans too. out of adjustment on that put the NSS out of whack.
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
S95 is offline
Old 11-17-2009, 11:01 PM   #3 (permalink)
If it is slop in the PRND... I believe there is also an adjustment, or set of screws to check, in the cab under the steering wheel. If I recall correctly.
sam
1996 PSD 2WD Auto, 190,000 miles
203 TStat, Napa 6637 open air filter
High Torque starter, Bilsteins, Toyo A/Ts, DIY electric fuel
samduket is offline
Old 11-18-2009, 06:16 PM   #4 (permalink)
yes my PRND21 slots line up good. i thought it might have been NSS but i was gonna check here first. this site is like my own personal mechanic. i will replace it and i hope thats the fix. thanks
ERIC
used to own:
