GP relay voltage - Diesel Forum - TheDieselStop.com
Old 10-15-2008, 09:31 PM   #1 (permalink)
GP relay voltage
What should the voltage be at the glow plug relay when the glow plugs are on? The voltage drop across the terminals is less then .3 volts.
Brad
96 F-250 extended cab long bed, 5-speed, Luk clutch, 4x4, 4.10, 3" lift, 35x12.5 BF All-terrains, 3" down pipe, straight pipe, shimmed FPR with gauge, stage 1 injectors, Dp-Tuner F-5 80 econ. 1100 HI-Idle 100HP Performance, Gauge style switch, ISSPRO pyro and boost, water temp, oil pressure, SuperDuty starter. 193,000 and counting
blaster1288 is offline
Old 10-15-2008, 10:11 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Your relay sounds good. The voltage should be whatever your batteries are at (unless you're measuring on the other side of the relay ... then subtract the 0.3V). If the voltage is low, maybe you need new batteries. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 10-16-2008, 06:36 AM   #3 (permalink)
Thats what I'm trying to figure out.... how much voltage is needed for these glow plugs to work properly? I have a significant drop in voltage when the glow plugs fire up. like maybe even a 3 volt drop...
Brad
Old 10-16-2008, 01:19 PM   #4 (permalink)
There will be a significant drop but 3 volts sounds pretty high. (I'll go check mine this morning and let you know for sure). I believe 2-2.5 volts is normal. Does your starter seems to spin as fast as normal? If not I would suspect your have weak batteries or bad battery cables. Have your batteries checked at a parts store. If they check out then look over all your battery connections really close for corrosion.
Griz
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
Griz is offline
Old 10-16-2008, 02:07 PM   #5 (permalink)
Originally Posted by Griz View Post
I'll go check mine this morning and let you know for sure.
Griz
My voltage drops from 12.7 with the GP relay off to 11.8 with the relay on. I reviewed my Ford service CD and it says the voltage should be 12-9 volts depending on the condition of the batteries. My personal feelings are, with a 3 volt drop your batteries are weak...for whatever it is worth.
Griz
Griz is offline
Old 10-18-2008, 11:04 AM   #6 (permalink)
Yea I'm going to get my batteries checked this weekend. One is kinda old, but I have a feeling that this isn't going to fix my problem. Thanks for all your help!!
Brad
