Hey all, I am getting ready to replace my glow plugs. Just a few questions. Will I need to replace the valve cover gaskets? Also, anyone know where to get motorcraft glow plugs for a good price? I have checked ebay, but they dont have motorcraft. Ill keep checking. And, if I need to get new valve cover gaskets, where should I get those?
Thanks!!
[Dreaming Of] 2011 Ford F-350 6.7L
Glow plugs from AutoZone, should still be under $10 each I think. ZD-11 is their part number, they come in Ford part bags with Ford part number on them.
Valve cover gaskets are re-usable unless you have a leak or a problem with a plug for the injector/glow plug wiring.
<font color="red">THIS LINK</font> will take you to the archived thread I started when I did mine. The link in the archived thread does not work any more and the part number for the glow plugs from AutoZone has changed to ZD-11. They are still the Ford parts in Motorcraft part bags.
The hardest thing was the back bolt on the passenger side valve cover. I used a 6" long 3/4 drive extension and a swivel socket after removing the vacuum plenum chamber mentioned in my post. A regular socket and u-joint are just too tall to fit. The extension rides in the "V" formed between the heater housing and the firewall, the socket fits right on the bolt head once the plastic box is taken out.
Hope these help out.
Dave / Believer45
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
That article mentions having trouble starting under 35 degrees. My truck starts now, but is taking a lot longer than it used to. Last winter I had the hard start problem. Do you think that the glow plug system is causing my lengthy starts? This happens even after the truck has been running.
I have checked the GP relay and it is fine. I know that my winter starting problems are due to the fact that that i need new gp's. Any idea what would cause a long start while its warm? Its not like it doesnt start, it will. It just takes longer than usual.
The first link in believer post will tell you how to check the glow plugs . Even if you test the pins and they could test bad it would be the harness under the valve cover not the glow plug. I replaced mind at 115k when the covers where off for injectors. They ohm'd out perfect and are in a box on the shelf.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Some people are blinded--because they have all the answers
Racerxpower.com for your upgraded E4OD/4R100 needs
Thanks!!
[/ QUOTE ]Check Ebay again. I bought a set of Motorcraft ZD-11's for $30.00. I just checked and on the first page of the Powerstroke stuff there are 2 sets up for bid.
Re valve cover removal: a 3/8" ratchet with an assortment of extensions, a 13mm std socket, a 13mm deep socket, and a 13mm flex socket (for the rear bolts on each side), will all be needed. A bench to stand on is helpful; I have a pair of 18" h little sawhorses, atop which I screw a 4' piece of 2x12. A stable place to stand really helps. A magnetic tray for all the bolts, etc is a wise idea, as is putting some duct tape across the big leads at the GP relay, so as to avoid those huge sparks when you short them with a tool. Use air to blow off the edges of the VCs and the general area prior to removal, to keep dirt out of the innards. When you've removed the VCGs, clean the connector sockets with brake or carb cleaner (watch out for backspray - you don't want that stuff in your eyes), then inspect the sockets for signs of melting or burning, or discoloration at the outer pins (#1 and 5); I've also found the tiniest cracks between pins 1 and 2, which allows the injector signal to short via the GP wiring, causing a (nearly impossible to find but very audible) miss.
As for your "hard hot start", that is almost always a sign of worn IPR o-rings. The replacement kit is under $20; google "IPR o-ring kit" and you'll find both parts and instructions.
Josh
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 General A/T on factory Alcoas, big front bumper w/4 really bright lights; F add-a-leaf, new alt x3, fuel pump x3, water pump x2, vac pump x 3, PS pump x3, SD starter, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, 265k miles on 25 Dec '10 and counting...
Long start warm could be a couple of things. Batteries getting weak, starter wearing (engine cranks but a bit slower and not fast enough for engine computer to allow it to start), even bad connections at the battery cables (battery end AND starter end as well), loose bolts/bad ground between the starter case and the mount. Starter motor gets its ground through the case. Even something as simple as needing an oil change can have an effect.
I recently installed a gear reduction starter from an automotive electrical house near me and am VERY pleased with the results.
Just a few things to check.
Dave / Believer45
Oil should be good. It has just over 2K miles on it. Batteries are new as of December. It sounds like it is cranking over a the same speed. I will clean the starter contacts and the battery cable connections. After that I will probably replace the IPR o-rings. Oh, I recently came back to college and its in a pretty small town. Everytime I need to go somewhere it is usually a pretty short trip. Most times the engine doesn't reach full operating temperature. Would this have anything to do with it?
