hard start warm or cold no power rough idle - Diesel Forum - TheDieselStop.com
Old 12-24-2012, 08:07 PM   #1 (permalink)
ok truck is a 1995 f 250 7.3 just started having trouble out of it. like i said first it has a hard start problem weather its hot or cold. then has a rought idle when i press the gas slowly around 800 to 1100 rpms it shakes a little bit. when driving down the road i can hold it to the floor and never make it past 60 mph it will cut out miss a little but just before anybody points the wrong finger i just rebuilt the injectors put bigger ones in. um it has new glow plugs and glow plug relay and the wiring harness thats under the valve covers are hooked up and as far as i know working right idk what it could be i'm leaning towards the icp or ipr but idk. i let the truck sit about a week when i changed the injectors out then when i finally got it started again this problem started any help at all would be a great help thanks for any help i just need a starting point
stephen_sons is offline   Reply With Quote
Old 12-25-2012, 10:01 AM   #2 (permalink)
Stan96's Avatar
I don't know if it would help, but maybe you could check the fuel presure at the schrader valve with a tire gauge, i think your supose to have around forty pounds or so but not sure.
1996 F-350 XLT 4x4, e4od, stock, Elect-rustproofing
2004, @32k mi. glowplugs, tires, drag-link
2010, @76k mi. Ball joints, u-joints, rotors
2011, @86k mi. glowplugs, drag-link, trany fluid
2012, @94k mi. Bilsteins, stainless brakelines, fuelbowl, lift pump, waterpump, steering lines, coolant filter
2012, @98k mi. Starter, positive cable, batteries
Stan96 is offline   Reply With Quote
Old 12-25-2012, 11:35 AM   #3 (permalink)
its holding somewheres between 50 to 60
Old 12-25-2012, 11:36 AM   #4 (permalink)
i really think it might be either the ipr or icp or maybe a cam postion sensor
Old 12-25-2012, 02:52 PM   #5 (permalink)
Stan96's Avatar
yea, i just try to rule out the inexpensive things first, so i guess toss in a cam position sensor, it's not that hard and only about 25 bucks
Old 12-25-2012, 03:12 PM   #6 (permalink)
thats what i was gonna do later this week put a cam sensor and icp sensor in its not popping up any trouble codes but that dont mean there not working right i bought this truck about 6 months ago and this is the first trouble its gave me its got 190,000 miles on it now and when i got it i know they had 3 cam sensors in the glove box so it sounds like this truck has a bad history with cam sensors
Old 12-25-2012, 03:37 PM   #7 (permalink)
Stan96's Avatar
Since it's Christmas, I'm guessing the guys who really know what there talkin about are doing other things, you'll get some good advice soon
Old 12-25-2012, 04:05 PM   #8 (permalink)
My Photos: (5)
Since it sounds like the classical VC wiring harness problem, I've got a couple of questions:
You said it was running correctly before you installed the new injectors, glow plugs/relay,and VC wiring. Did you replace the connector outside of the VC gasket?
I can't tell from your description if the truck ran well after the injectors were installed, but a week later they didn't, or if the truck never ran correctly after the mods.
If the truck ran correctly after the mods, then developed problems, I think you're on the right path. If it never ran correctly after the mods, I think you need to go back and check the wiring harness again, and especially the pigtail connectors outside of the VC.
Michael
1995 F250 4x4 Supercab PS
artificer is offline   Reply With Quote
Old 12-25-2012, 11:01 PM   #9 (permalink)
so i feel stupid but i checked my work on the pass. side head pull my number 1 and number 2 injector back out the number 1 nuzzle was black and the number 2 was shiny and new look took that injector a part and realized i had the check plate and ball upside down so basiclly i had a dead injector turned it around put it back in and it ran like a champ again easy mistake i guess. but i dont think i'll ever take injectors apart and redo them again to easy to put something back together wrong i got real lucky this time and only had one injector not working but thanks for all your alls help
