Re: Heater blower speed switch
I'm not sure on our trucks but on an 84 that I had the actual speed control was mounted to the blower housing on the firewall. It consisted of restive wire that would control the speeds of the fan. I tore the dash apart on that truck trying to find out where the speed control was to find it there. So if you can find where the power line goes into the blower motor there should be a screw or small bolt holding it in that you can remove and check it out. Hope that this helps, like I said that was for a 1984 truck. <ul type="square"> Jim[/list]
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
