I went & started my van & it has 4 dead cylinders. Ran good earlier today. 2 4 6 8 are all dead. I was going on a trip tomarow. Any ideas? Thanks for the help.
1995 E350 Beans stage 1 injector, chip, triple disk convertor
Valve cover gasket & wiring both harness were replaced when injectors were. About 15k miles ago. I can see 1 harness going & causing 2 cylinders to miss, but both harnesses at the same time?
Maybe chip is not making good contact .Try removing chip , cleaning contacts and trying it again. Are there any codes present ? Is the Idm OK ? Also when you replaced the UVC harnesses , was the engine harness OK ? I mean not burn't at all ?
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
Just went out & removed chip. No change. Is there a way to check IDM? Harness was burned some, but I replaced the connector ends.
If the idm senses a fault is shuts down the whole bank, it could just be one wire burnt causing the problem,
but as mentioned, I would check the idm for water, its more common on the vans then the trucks to find water in them I believe.
Thanks for your help. I replaced the harnesses again & valve cover gasket & connector ends. Ran fine for a couple months. It acted up again & than ok for 1k miles. Now it has the same problem again. Now I have a code P0270. Injector # 4. I took the IDM off, and there is no water in it. Any other ideas? The harness from IDM to VC is .1 ohm.
