HELP! How do you install the clutch slave cylinder on a F350? - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 07-08-2005, 05:57 PM Thread Starter
There's got to be some trick, I don't have the strength to compress the slave cylinder spring and get it into position. Any ideas?
Thanks,
Jim
94, F350, Crew, 4X4, Exh brk, 4" DP, Chip, ICooler, 5spd manl w/Luk clutch, Kelderman air ride, 155k mi
jim95350 is offline
post #2 of 10 (permalink) Old 07-08-2005, 07:40 PM
Re: HELP! How do you install the clutch slave cylinder on a F350?
I just did mine after my LUK and I rember it being kind of tricky but I just pushed the rod in and twisted some and it went in, didnt seem right when I was doing, too much force but its working fine. Do you have the clutch road under the dash disconnected?
Scotty
1997 F250 extcab short bed 4X4 OFF ROAD 5speed 104K, Tymar intake, Tymar 4inch turbo back exhaust, LUK SMFW, AIC, gutted EBPV
Boone NC
Tarheelstroker is offline
post #3 of 10 (permalink) Old 07-08-2005, 10:24 PM Thread Starter
I'll try disconnecting rod under dash but I don't understand how that could be the problem since it is a hydraulic connection I would think that the fluid would be free to flow back into the reservoir? At this point I'll try anything though.
Thanks,
Jim
jim95350 is offline
post #4 of 10 (permalink) Old 07-08-2005, 11:00 PM
If it is a new slave cyl, leave the retainer band on the slave until you install it and then pull the retainer band off.
The retainer I am talking about comes on all new ones so that the plunger stays put until you install it. It's like a strap over the plunger that fits into the notch on either side.
Hope this helps.
96' F-350 single cab 4x4, 5-spd,205K, SB OFE, BHAF, 3"dp with 4" straight, 6-pos chip, shimmed FPR, 18K, 4.11's, Hankook RT03 35's, pyro/boost (pre-turbo), RSK. Losing in Divorce
66' Bronco, roller SEFI 351W,Explorer Serpentine,C6, Atlas, D60's, Detroit/ARB, OBA, 4-link fornt and rear, fully tubed and narrowed, 110" wb, 42's
2005 Dodge Dually CC 4x4, Cummins,6-spd, Leveling kit, BHAF, guages, CFM+, Arson CP3, Smarty TNT, 97K
tatipton is offline
post #5 of 10 (permalink) Old 07-09-2005, 09:28 AM Thread Starter
It's the old slave so there's no band. I took it off to help bleed the new master cylinder. I thought about some kind of band to hold it in but haven't come up with anything yet.
jim95350 is offline
post #6 of 10 (permalink) Old 07-09-2005, 01:37 PM
Pop the master cylinder rod eye off the pin and then push the slave cylinder in. It does not take much effort if nothing is binding the system. If there is a bind, you need to isolate where the bind is and correct it.
Bill
Bone stock 94 1/2 DI turbo 4x2 F250, Rancho steering stabilizer to eliminate front end shake, sensor safe clamp mod, filler neck mod
Gun Control: The ability to consistently hit what you are aiming at.
Graduate, UA, Mech. Eng.
arizonian is offline
post #7 of 10 (permalink) Old 07-09-2005, 04:11 PM
I was interrupted in my previous reply, so now I have time to finish.
All new master cylinders are not alike. The problem masters seem to have a longer rod than the original master cylinder. One way that I have seen to cure this problem, and I did it on mine, is to space the new master away from the firewall. The dimensions required seem to vary, but .200" should work, or 3/16" if you don't have a mike handy. One member used 1/4" plate and got it to work.
There is a plate that is glued to the fire wall with a butyl compound that can be removed. Washers can then be glued down and the plate set over the washers. Use some RTV to fill the gap and your firewall won't leak.
The risk of not having the spacing correct on the new master cylinder rod eye is to constantly have a preload on the clutch release, just like riding the clutch pedal, and having the clutch slip when under a load. Several member have burned up their new Luk or SBC within a very short time of installation.
Bill
post #8 of 10 (permalink) Old 07-09-2005, 08:26 PM Thread Starter
Thanks all, I removed the link from the pedal and was able to pop it back in no sweat. I think I have the right master as the link eye easily slips over the pedal stud. BTW, I also installed the heim joint that is sold on ebay (I know I got ripped off) but I'm tired of the stupid plastic bushings. If anyone decides to get the heim from ebay, beware the heim bottoms on the clutch switch rather than the pedal bottoming on the bumper so I had to do some mods to the switch which I didn't really like but it seems to work fine and the pedal has a nice smooth feel to it now.
Jim
jim95350 is offline
post #9 of 10 (permalink) Old 07-09-2005, 11:20 PM
What would be the symptoms of the bad clutch master, just put a new one from advance auto and drove it some on the old clutch and have been using it for about 350 miles on my LUK with no prob.
Scotty
Boone NC
post #10 of 10 (permalink) Old 07-10-2005, 08:40 AM Thread Starter
I had some oil at the firewall.
jim95350 is offline
