Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-30-2008, 07:56 PM   #1 (permalink)
HELP.. no power and rough runing
this problem started on the way home from work. started fine then got on the road and it lost power i had it flored and couldnt get over 40mph black smoke was roling out but it acted like it wasent timed right. the check engine came on and so i pulled over and hooked up my scan tool no codes found. then i shut it off then started again it started normaly then the check eng comes on and again sounds like crap. i went home pulled the chip and it still did it. then i took it for a drive later and it was fine then later it did it again. i poped the hood and wiggled the IDM wires and it quit then i pulled every thing apart and wiggled more put it back together and it seames fine then it did it one more time. i changed the fuel filter, cleaned the fpr screen and replaced the cps. im just wondering if this is a sighn of a IDM craping out or a PCM. i also didnt find an loose broken or bear wires any ideas would be helpfull sorry about spelling im bad.
96 powerstroke 7 inch lift,35in tires, cold air intake,4in exhaust 6in tip.DIY stage1 superchip 1200 gold series 2001 superduty axels.
Fdturbobrando is offline
Old 07-30-2008, 09:35 PM   #2 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
was it running when you wiggled the idm wires?
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is online now
Old 07-30-2008, 10:17 PM   #3 (permalink)
S95
if your EBPV is still intact it may have slammed shut on you, thus the no power and black smoke. Verify its position and unplug it, or gut it. Check it just to eliminate it as a possable.
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
EOT MOD : xxx.thedwilsons.com/powerstroke/PSDhome.html
S95 is offline
Old 07-30-2008, 10:18 PM   #4 (permalink)
Sounds EXACTLY like what happened with my truck. Ended up being the injector wiring at the valve cover. I kept having to use carb cleaner on the connectors just to keep it running. After I limped it home, I purchased the valve cover gaskets and the plastic connectors from the harness to the gasket. When I pulled the connectors out of the old plastic onnector, I noticed that the 2 outside wires on the rear connector on the drivers side of the engine were actually burned off! I spliced new new end on and now the truck runs great.
I got the gaskets from NAPA for about $70 each - ouch - and the connectors from Ford for about $40 (included a removal tool for the connectors)
waverous is offline
Old 07-30-2008, 11:23 PM   #5 (permalink)
yes it was running
Old 07-30-2008, 11:27 PM   #6 (permalink)
wires are disconected on the ebpv
Old 07-30-2008, 11:32 PM   #7 (permalink)
ya i thought of that also but if that was the case would the problem come and go like it has. when i did my injectors i noticed the were a little burnt but didnt have the funds to fix them then.
Old 07-31-2008, 12:01 AM   #8 (permalink)
blageurt's Avatar
Are you saying you re-installed burn't connectors? I think you have answered your own question . . . Hopefully you have only burned the UVC harnesses and not the gaskets OR the Engine harness connectors which cost alot more. When you eventuallly replace them , fill ALL connections with Dielectric grease so they don't burn up again. I would also check your Intake system for leaks too along with MAP sensor . Good Luck
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 07-31-2008, 07:01 AM   #9 (permalink)
ok ill change them and see where it goes from there thanks for every ones help.
Old 08-01-2008, 10:14 AM   #10 (permalink)
I'll second the intermittent problem can be your UVCH and gaskets. Mine was off and on again for a week till it finally crapped out. I was only running on 7 cylinders. Good thing you talked to this forum, the dealership wanted over 3K to replace a non-functional injector, and IDM they claimed was shorted. All said it was a 39.99 harness that fried. Another thing to do is replace your GP's if its been a while
1996 PSD, XL, 2wd, SRW
331,000 miles. Amsoil Synthetic, and Cat extended life coolant. Diesel Site 203* T-stat. 4 inch straight piped exhaust. Tymar intake. Leather Captains Seats. 120 gal. Heated Veggie tank in rear. Shimmed FPR. TS 6 Pos. Chip (stock, hi-idle, 50,75,100,140). DIY Stage 1 150cc injectors. Valaire Con O Clutch. Stainless 10" drop 15K hercules rear bumper. 3 gauge pillar pod: autometer digital boost, pyro, voltmeter. BFG AT's 285/75/16
Pulling a 31' 1985 Airstream Excella
1986 Hunter 23
huberjoshua is offline
