How big are my fuel tanks??? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 02-13-2006, 10:45 PM Thread Starter
Could somebody tell me how many gallon tanks i have on a 97 longbed? Thanks!
My Trucks,
1999 Dodge 2500... 438HP, I just got a superchip...
1997 F250 ext cab 7.3, 5spd, 4x4, with some modifications
(Sold)
2007 Q&S Gooseneck, 25+5 with tandem duals.
1966 Mustang coupe, (Sold)
1984 Chevy K10, Built motor, lift, all the good stuff. (Sold)
1997 F150 XLT ext cab, sb. (Sold)
Myspace:
Ben97 is offline
post #2 of 13 (permalink) Old 02-13-2006, 10:48 PM
Sapps's Avatar
Re: How big are my fuel tanks???
My 95 takes around 31 gallons when empty. So my guess is around 15 a piece [img]/ubbthreads/images/graemlins/shrug.gif[/img]
But Im new to the OBS trucks I just got mine so I might be wrong.
95 F250
97 F250
02 F350 Dually
07 Dodge 3500 Dually
Soon to be 2011 F350 Dually
Sapps is offline
post #3 of 13 (permalink) Old 02-13-2006, 11:16 PM
I believe they are 18 front and 18.5 or 19 rear
97 F350 PSD 5speed CC 4X4 210,000 miles, "Tymar" Intake, 3"-4" Downpipe, 4" exaust, Autometer pyro & boost gauges, 4 pos.chip by Dale I., Baldwin oil Bypass, HPX Mod, Exaust Brake, Fumoto Valve
You Enter And Leave This World With Only 2 Things
"YOUR NAME AND YOUR WORD"
Do Your Best To Keep Them Both Intact.
slcragun is offline
post #4 of 13 (permalink) Old 02-13-2006, 11:26 PM
My Photos: (61)
1995 Ford factory service manual shows all 1995 f250 and f350 diesel models to be 19 gal front and 18.2 gal rear refill capacity <font color="red">EXCEPT</font> the regular cab F350 4x4 - front tank is listed at 22 gal on that one, rear is still 18.2 gal.
Your 97 should be similar, I think.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
, LUK clutch, homemade
, open element
, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
post #5 of 13 (permalink) Old 02-13-2006, 11:28 PM
According to the FAQ section here at TDS a 1997 extended cab holds 37.2 gallons... 19 in the front, 18.2 in the rear.
Craig
2000 Ford F250 Lariat 4x4 Auto SuperCab LB PSD
2L Motorsports transmission (Precision 3 disk converter, valve body, upgraded clutches), V10 tranny cooler, TS chip, MBRP 4" exhaust, 4" to 5" tip, Auto Meter Z Series Boost, Pyro and Tranny, Poor Man's DIY intake, Boost Relief Valve, Crank Case Vent routed under truck, AIH plug
Both powered by 2L Motorsports
2L Who??
CraigPSD is offline
post #6 of 13 (permalink) Old 02-13-2006, 11:31 PM
I have never ran my back one dry, but I can get right at about 22 gal in my front tank filling up to the top of the filler.......
1996 F-250 Powerstroke, 5-speed, 100% stock(execpt SMF kit, clutch arm mod and stancor relay)
plug is offline
post #7 of 13 (permalink) Old 02-14-2006, 05:29 AM
Bigger then you think. When the gage hits the RED empty mark, you still have around 4 gals left. The needle will go over a full needles width past the red mark before you run out.
Counting the filler neck that I can fill up now, I have put over 20 gals in each tank at one time or another.
I just ran my truck untill it ran OUT of fuel in one tank then switched to the other one so I would KNOW how low I could go. It doesn't hurt the truck but I don't do it anymore now that I know. It spit &amp; spurtered a bit but kept running and cleared up in a few seconds.
book says 18 &amp; 19 like has already been said.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
post #8 of 13 (permalink) Old 02-14-2006, 07:18 AM
straight from the book pictures [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
fuel tank
fuel tank sizes 2
RYAN
GAUGES, INTAKE, EXHUAST, SBC CLUTCH, CHIP, BDP INJECTORS, BILSTEINS, BUSHINGS...AND A WHOLE LOT MORE..
B99 BIO DIESEL SUPPORTING AMERICAS FARMERS.
US NAVY
looking for an ext cab 4x4 short bed DURAMAX!!! keeping the obs of course.
1997PSD4ME is offline
post #9 of 13 (permalink) Old 02-14-2006, 11:42 AM
if you have two the front one is 16.5 and the back is 18.5 hope that helps alan [img]/ubbthreads/images/graemlins/cool.gif[/img]
Pattee is offline
post #10 of 13 (permalink) Old 02-14-2006, 12:44 PM
Sapps's Avatar
I knew the pros would come on here and correct me. Thanks
95 F250
97 F250
02 F350 Dually
Sapps is offline
post #11 of 13 (permalink) Old 02-14-2006, 02:31 PM
My '96 is a reg. cab long box, and I've put as much as 24.2 gal. in the big front tank, &amp; 20.2 gal. in the little rear tank.... both the original factory tank and the OEM replacement tank I installed about 3 yrs ago when the old one rusted out. Been many times I've put in 40-42 gal. at a fillup. That 800 mile range sure is nice.... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
post #12 of 13 (permalink) Old 02-14-2006, 03:04 PM
Anyone ever install a SD tank in the front of an OBS?
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
post #13 of 13 (permalink) Old 02-14-2006, 03:08 PM
Dick Cutting's Avatar
My Photos: (28)
I went back and did a search of this same topic/question which I have replied to several times and one of the posts I made is here.
Dick
TheDieselStop.Com Moderator & Former Photo Editor
Had a May '02 F350 7.3L SC Lariat 4x4 Auto In 5/2016 it had 321.1K+ miles
Had a June '97 F350 7.3L Reg Cab XLT 4x4 Auto SRW, OEM Radio w/CD, In 5/2016 it had 208.1K+ miles
Dick Cutting is offline
