How to block off High pressure hose ICP - Diesel Forum - TheDieselStop.com
Old 11-16-2009, 10:51 PM   #1 (permalink)
gbickel's Avatar
I want to test to see which head is leaking. How do I block off the High Pressure line with out the special tool?
93 F350 Crew cab 5.8 E4OD still going strong! 88 Bronco 5.8 C6 68 F 250 Camper special 390
gbickel is offline
Old 11-16-2009, 11:15 PM   #2 (permalink)
The lines can be removed with standard flare wrenches. A hydraulic shop should have any required plugs or fittings required to isolate each head.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 11-23-2009, 12:03 PM   #3 (permalink)
gbickel's Avatar
Ok, I blocked off the passenger side and no smoke. I have pulled the injectors and found the very top orings look bad but no horrible. We thought we might have seen coolant in the hole but we see nothing with pressure tester on system. It he top oring being bad enough to cause lots of white smoke?
1996 F450 7.3 25,000 on engine, has been sitting for 1 year.
gbickel is offline
Old 11-23-2009, 06:55 PM   #4 (permalink)
Nit
you've only made 1/2 a test, the ICP must be in teh loop for the computer to see enough pressure to start, to do thsi test properly you need a real pressure gauge in teh system and an adapter for the ICP. Otherwise you can only test the left side
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now pictures
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
