How does the Fuel heater unplug? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 12-09-2007, 10:25 PM Thread Starter
I bought my new powerstroke (1994) and it died on me after about five miles. The fuel heater shorted out, taking the #22 fuse with it. I can not figure out how to unplug it. I had to cut the wire (and did it too close to the plug to reuse it).
I know, that was stupid, but I was over an hour from home and it was butt cold.
So, I need to figure out how to get that off, then find another one and solder it in. Can you help me figure this out?
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
post #2 of 6 (permalink) Old 12-09-2007, 10:39 PM
BlueMule's Avatar
My Photos: (12)
Re: How does the Fuel heater unplug?
Use a flat screwdriver between the connector and the fuel bowl. Just a little twist should pop it right off.
Rodney#33
BlueMule is offline
post #3 of 6 (permalink) Old 12-09-2007, 11:27 PM
Most folks just leave the fuel heater unconnected. It's very expensive to replace the components, and, even when working correctly, it's positive effects are negligible.
95 F-350 CC DRW Utility Bed 4x2 E4OD 264K
95 F-350 CC SRW 4x2 E4OD 231K
96 F-350 SC DRW 4x2 5-spd 265K
96 F-250 SC SWB 4x2 E4OD 292K
97 F-250 SC LWB 4x2 E4OD 143K
Schmokenwagon is offline
post #4 of 6 (permalink) Old 12-09-2007, 11:56 PM Thread Starter
You guys down south don't even fix glow plugs or install block heaters on reman engines.
1996 Town Car
post #5 of 6 (permalink) Old 12-09-2007, 11:59 PM
Patrick Feeley's Avatar
My Photos: (19)
On mine, the external bowl connection for the fuel heater is very hard to remove. I fubar'd the fuel heater "thermostat" (the part that the wire connects to and seals on the bowl) trying to get the stupid thing disconnected and had to replace that. I prefer to disconnect the fuel heater from the spade connector inside the bowl (yeah, you have to drain the bowl and remove the filter, but it beats replacing another $40 part). Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #6 of 6 (permalink) Old 12-10-2007, 12:13 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 82FordTruck</div><div class="ubbcode-body">You guys down south don't even fix glow plugs or install block heaters on reman engines. </div></div>
True, block heaters are optional here, but glow plugs are definately needed. I moved here after living in Alaska for 10 years, so I know about cold temps. In my opinion, you don't need the fuel heater unless temps are well below zero (farenheit).
