How to test MAP sensor?? - Diesel Forum - TheDieselStop.com
Old 02-13-2008, 04:22 PM   #1 (permalink)
amberjax's Avatar
Anyone have the skinny on how to test a MAP sensor?? I've seen several posts talking about the MAP sensors causing the mpg to drop. Mine seems to be doing the same thing for no obvious reason. Like to know how to test it before buying one.
2002 F350 CC,Short Bed, Dually w/ 7.3L, Air Raid intake, 3 gauge pod w/ISSPRO V2 gauges, Overhead gauge mount with DP Tuner gauge switch, DP F6 tuner w/stock, 1300 hi idle, 80 econo, 120 race, 40 & 80 tow and decel tunes. 4" turbo back Magnaflow exhaust.
http://community.webshots.com/album/576806969VrqaZx
amberjax is offline   Reply With Quote
Old 02-13-2008, 04:38 PM   #2 (permalink)
If you don't have a scanner ,, try unpugging it ...Have you checked the fuel pressure ?...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline   Reply With Quote
Old 02-13-2008, 05:30 PM   #3 (permalink)
amberjax's Avatar
No, haven't checked the fuel pressure. Have a new pump (less than a month old) and have shimmed the fpr.
If I unplug the sensor will it set a code??
Old 02-13-2008, 05:41 PM   #4 (permalink)
blageurt's Avatar
My Photos: (9)
Try spraying some electric contact cleaner inside the Map sensor where the hose goes on. It seemed to have decreased the black smoke on mine. I don't know about Mpg's yet because Its been so cold here lately there's no point driving around wasting fuel just to test it out. I might buy one too. I priced them at Powerstroke shop for $ 127 plus shipping. I will look in a junkyard too apparantly the I-6 Econoline has the same sensor as me. part # F4TZ-9F479-A
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Michelin LTX
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
blageurt is offline   Reply With Quote
Old 02-13-2008, 06:01 PM   #5 (permalink)
Yes , but it won't hurt anything while testing
Rick.....
Old 02-13-2008, 06:53 PM   #6 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Before rushing out to your local boneyard to find the Econoline version (or just another MAP sensor), you might want to read this: "TSB 94-23-15, LOSS OF POWER - 7.3L DIRECT INJECTION TURBO DIESEL - INCORRECT MAP SENSOR".
Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline   Reply With Quote
Old 02-13-2008, 08:52 PM   #7 (permalink)
Question
And what are the symptoms if you unplugging it to see that it is bad? changes something in the idle, WOT, or what?
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline   Reply With Quote
Old 02-14-2008, 12:21 AM   #8 (permalink)
STurbo90's Avatar
My Photos: (9)
The drivability should be different.
If the map sensor is unplugged the pcm will default to a set value.
If the map is bad and sending the wrong data to the pcm it usually shows in poor acceleration.
Usually when complaints about poor acceleration came up testing the map sensor was one of the things most checked. It seems just recently that people are saying the mpg improved when they replaced the map sensor, but they were not complaining about any drivability issues. So I don't know if its a direct relation, or they just didn't notice any poorer performance.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline   Reply With Quote
Old 02-15-2008, 08:24 PM   #9 (permalink)
Thumbs up
Thanks a lot, and yes I have read that about the MPG, and Im having poor MPG and not any poorer performance, thats why asked that. Im going a try, unplugg the MAP sensor and let see what happens.
