Hpop plug - Diesel Forum - TheDieselStop.com
Old 11-18-2009, 11:35 AM   #1 (permalink)
97 Manual's Avatar
Hpop plug
Before I go stripping the plug out, what size wrench do I need to open the inspection plug on my hpop? It looks like the po may have used whatever was lying around??? Thanks
'97 7.3L Powerstroke in an '89 F-250
3 pedals & 2 sticks
97 Manual is offline
Old 11-18-2009, 01:44 PM   #2 (permalink)
bullyandbif's Avatar
3/16 allen fits mine
bullyandbif
'97 F350 201K , IDM mod.,shim FPR,gauges,ford reman trans @ 198k
bullyandbif is offline
Old 11-18-2009, 02:07 PM   #3 (permalink)
97 Manual's Avatar
Thanks bullyandbif,
3/16 didn't fit right (maybe it was really "worked"), that's why I posted. Maybe I'll try a different wrench. By the way, how did you shim your fpr.
3 pedals & 2 sticks
Old 11-18-2009, 04:28 PM   #4 (permalink)
Try a 1/4" square drive.
Good Luck
Midwestman
95 350 CC SRW 4X4.456K. Amsoil everwhere w/dualbypass filter. Early Centurion model custom paint (white with grey striping) Grey shell, brushguard, Flexsteel leatherseating wood trim and overhead console. BTS hold on tight E4OD tranny. Custom chip by Cale Thompson at BTS. Hypermax DP. Tymar Open element intake. Tru-Cool 28,000 GVW trans cooler plus Super Duty trans cooler. Super Duty Intercooler with GTS pipes. CCV mod. 3 pod A pillar guages with Isspro Pyrometer,Boost and Tranny temp guages. Fumoto oil drain. John Deere coolant eye. Sylvania Ultra Silverstars. Joe Servo IDM. BABY SWAMPS. Magnaflow 4" exhaust. Tymar Coolant Filter. Sirius satellite radio. Kelderman Air Ride on the rear. Autolights clear diamond headlights. Mods as the budget will allow.I think I am almost finished.
midwestman is offline
Old 11-19-2009, 07:09 AM   #5 (permalink)
Originally Posted by 97 Manual View Post
Thanks bullyandbif,
You could try a metric allen or get a new plug and use a punch to tap/turn the old one out. Also you can make a taperd wrench so you tap into allen head.
Off hand I dont have a link to shim fpr but a search on the upgrades and aftermarket forum will yield you all the info. I did the bb method (only I used a very small stainless shcs behind spring) to get more pressure.
bullyandbif
Old 11-19-2009, 02:32 PM   #6 (permalink)
97 Manual's Avatar
Thanks, I'll give it a whirl
3 pedals & 2 sticks
