Re: HVAC Blower Help!
Hey Roy,
I think they are still using a speed system that had short lengths of resistor wire in series with the blower motor to slow the motor for different speeds and some of those coil resistant wire will burn out and the blower will not work on that speed, this deal is mounted on the blower housing with a hole large enough for the res. wire to stick inside the housing, the last one i saw had a small rectangular insulated plate with two terminals on the outside to hook the wires and the res. wire was on the other side of the plate and inside the blower housing and the plate was mounted to the housing with two sheetmetal screws, so check on the blower housing to see if you see anything that looks like it.
Thanks,
Bill Miller.
1995 F250 XLT Powerstroke, Supercab, E40D tranny, 3.55 limited slip diff. (with all the bells and whistles) bucket seats and console, electric windows and door locks,intermitnent wipers, tilt wheel, cruse control, overdrive and turbo my IDI has none of these.
1985 Ford F-250 6.9L Std.cab,C-6 tranny, 3.55 Diff. DEEZEE Running boards, added factory Tach with existing circuit board, heater water bypass valve.
My Photos
