Icp - Diesel Forum - TheDieselStop.com
Old 10-18-2008, 09:45 AM   #1 (permalink)
Icp
Been having problems with the pickup since I changed the vcg's and the uvch's. drove it to town, shut it off, and now it won't start, cranks fine, has fuel pressure, not sure about high pressure oil. On the hpop there is a connector that is down below the hpop temp sender, this will move from side to side, but it does not come out, is this the icp? It has a two wire connector hooked to it and was wondering if you disconnected the connector and hooked up a jump wire to it, would that give a signal that the high pressure oil is there and make the pickup start, telling me that this sender is bad? The cel comes on and goes off when you turn on the key, but I am not getting any smoke when cranking.
2002 3/4 ton 4x4 auto, edge juice and attitude, 4" magnaflow exhaust,97 4x4 CC 5sp. aftercooled, gutted,new valeo smfw clutch, no silencer, cleaned, , amsoil front to rear, Western diesel 4 page chip, 3 in. downpipe, 5 inch exhaust, boost and pyro guages, equalizer hose between the heads, WWJD on the sides. Also 86 F250 4x4 sc 5sp Hypermax turbo 3.5 exhaust, aftercooled,balanced, 640,000 miles
tupco is offline
