IH Throttle problem - Diesel Forum - TheDieselStop.com
Old 10-16-2008, 02:23 PM   #1 (permalink)
IH Throttle problem
Hey all not shure if you guys will be able to help me with this but maybe you will. At work we have a 97 IH 4700 single axle truck that intermitently the throttle quits working if you shut the key off and turn it back on it will be fine for another 10 or so minutes and then the same thing. We have already put in a new potentieometer(? spelling). I believe the electrical systems are basically the same as our trucks so thought asking you guy would be worth a shot. thanks for the help
97 F-250 7.3 Powerstroke XLT, extended cab, automatic, 4X4, 275,000 miles, 3.55 Limited Slip, Tymar Intake, stock exhaust with delete pipes, 6 position Wildman chip, Issopro pyro, tranny, and boost gauges, and the bright box.
-93 F-250 7.3 IDI, XL, extended cab, 5 Speed, 2X4, ATS Turbo, 150,000 miles
-06 Honda Rincon 680, EFI, 4X4
-00 Yamaha Big Bear 400, 2X4
97_73stroker is offline
Old 10-16-2008, 10:49 PM   #2 (permalink)
JMCX's Avatar
Our trucks have a micro switch adjacent to the potentiometer to signal the computer when the throttle has left or returned to idle position. Idle Validation Switch (IVS). It is part of the safety system in this drive by wire stuff and I'm sure IH has something similar. If the switch is malfunctioning it may be your problem.
97 F350 SW CC 4X4 Auto, IDM mod, TW six position, DIY Stage I's, Beans D66 Turbo & 3" DP, 4" straight exhaust, Mobil 1 ATF, Tru-Cool 28k, Fuel filler mod, 99 Intercooler, Open Air Filter, SmittyBuilt stainless nerf bars, Trans-go tugger kit and Billet TC
04.5 Dodge 2500 QC 4X4 600 Cummins auto (work truck), 72 Mach I 552 stroker
JMCX is online now
