Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-31-2008, 08:52 AM   #1 (permalink)
RowdyOutfitters's Avatar
Injection Pressure Above or Below Code?
I was on my way back from Fort Worth to Abilene, TX after picking up a horse trailer. I had the cruise set on 75MPH when I hit a small hill on I-20 close to my house. She was screaming up the hill with no problems at all and about half way up I heard a click under the dash, then all power from the engine went. I wasn't blowing smoke, and the check engine light came on. I limped it up the road at about 40 MPH to an exit. Checked all the connectors and shut it down and restarted. Check Engine went out and the truck sounded like it was running back to normal instead of really quite. I turned the A/C off and set the cruise on 65MPH and came to another hill about the same size and grade. Half way up it did it again. Ran it home, and pulled the codes and got the 1211 Code.
I am at a loss here. I figure it is the IPR or the ICP, what do you all think?
1995 F-250 Extended Cab, 7.3L PSD, RDS Stage 1 Injectors, EDGE Program +65HP, Bully Dog Down Pipe with 5" Big Rig Exhaust, 5 Speed Tranny with LuK Singlemass Flywheel and Clutch, 3.73 Ratio, and only run Marvel Mystery Oil in the fuel to combat the stinking new diesel. 220k + on the engine.
Rowdy Outfitters/Rowdy Acres sport ponies, pony carts, woodworking, and metal working.
RowdyOutfitters is offline
Old 07-31-2008, 09:06 AM   #2 (permalink)
Not to over simplify ,,but have you checked the oil level?...
You get that code when ICP is not at the expeccted level for 7 seconds or so...
May need an oil change also ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
racerxautomotive.com
action4478 is offline
Old 07-31-2008, 11:21 AM   #3 (permalink)
The oil level is good, and I only have about 3k on it since the last oil change. I did add two quarts of Marvel Mystery Oil to the crank case during the 2k oil filter change. May be to thin I guess, but I have had a problem with my truck for a while. I has had a miss like sound, loss of power, and mileage. Changed CPS, Filters, Fuel Pump, Injectors, UVC's and Gaskets, and had a bad IDM that has been changed out. With all this changed, the mileage came up and power definitely went up with Stage 1's, but there is still a missing sound. Just figured I would run it till it went since no codes are ever thrown and no mechanic can tell me what it is.
When the Check Eng light came on and the computer switched to what I guess is a Safe Mode, the engine ran quiter and the missing sound seemed to have went a way, or at least not as noticable at all. ????
Old 07-31-2008, 11:32 AM   #4 (permalink)
The only thing I can think of that may be happening during the CEL ,,would be the IPR may be commanded to close the drain to raise ICP ????
Is the ICP sensor leaking oil ?...
Rick.....
Old 07-31-2008, 11:39 AM   #5 (permalink)
I changed the ICP senor with my mechanics spare to see if it was causing any problems with the missing sound, no change, so I put mine back in and pinched the o-ring with leaked some oil for about a week. I got a new o-ring and no more leaking, well at least it isn't hitting the ground any more. I haven't cleaned it out of the valley yet, but doesn't seem to be leaking any more.
Old 07-31-2008, 01:30 PM   #6 (permalink)
Does the mech have a scanner to watch ICP & IPR data while driving?...
Rick.....
Old 07-31-2008, 02:49 PM   #7 (permalink)
That is what I plan on finding out today to see if he can.
Old 08-23-2008, 10:46 PM   #8 (permalink)
I talked to my friend about hooking the scanner up and watching the pressure. He said that it really would not show much that would tell us anything. I changed the orings on the IPR. It wasn't leaking, but the shaft that the connector part slides over was filthy. Cleaned it up, and the truck started great and was running smooth again. Took it down the road and opened it up and she ran great. Next day, which was today, I was in fifth gear running about 50-55mph and started to get back on the throttle and it did it again. Check engine light came on and the PCM switches to a SAFE MODE, which has no power.
I restarted the engine to clear the CEL and ran in third gear for about 7 seconds with the engine rapped up to 3k and it did it again.
Not sure what to do here. At a loss.....
Old 08-24-2008, 12:31 AM   #9 (permalink)
STurbo90's Avatar
My Photos: (9)
Have you tried to get the ce light to come on without the chip?
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 09-01-2008, 06:45 PM   #10 (permalink)
I changed the ICP and no change. Took the program off, no change. Every time I put my foot on the gas pedal, it goes to safe mode. I am going to try changing the IPR valve.
Old 09-14-2008, 09:55 AM   #11 (permalink)
It was the IPR. I guess it was stuck. It is finally running right again. I pulled my horse trailer all over the place with no problems.
Old 09-15-2008, 02:49 AM   #12 (permalink)
brian213's Avatar
Very cool. Good job figuring that out.
-Brian
1995 F-350 PSD XLT CC/LB >250k miles...AirLift 5000 rear bags, excellent!
Have replaced the water pump, power steering pump & A/C compressor just prior to or via failure.
I roadrace a 125GP bike..haul it with a huge truck & a 20' 5500# trailer...whee!
It's looking better: replaced fender, front bumper & hood hinges.
-- pulling a 20' trailer and 1997 Honda RS125
brian213 is offline
