Injectors in and IPR still 0% - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 04:32 AM   #16 (permalink)
Window&Door's Avatar
Keep oil changed and use a good wix oil filter
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
Old 11-02-2009, 10:52 AM   #17 (permalink)
Originally Posted by 4stroke View Post
I guess I'm not paying attention. In this link it clearly states the edge filter is under the non servicable plug
https://www.dieselsite.com/pdffiles/...structions.pdf
I'm hoping my problem exists in my HPOP. I'll try to get into it in the next few weeks
Thanks again
Great link ...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 11-02-2009, 02:53 PM   #18 (permalink)
4stroke's Avatar
Vref should be right at 5 V, so that could be your problem. Possibly the PCM is bad, as that's where the Vref signal comes from. Do you have access to another PCM to try?
I wish I did. My truck is a california truck so I get the feeling that if it is my PCM I'm going to have a difficult time finding a replacement. The only numbers I could find on my PCM are MME2. After looking here
PCM Codes - 1994-1997 Power Stroke FAQ
I found that it leads to a F7TF-RC.
Can you think of any other possibilities as to why the Vref is only 2.49?
My only thought was that maybe one sensor wire was shorted to ground but that should lead to 0 volts and all sensors reading voltage low. Right now my truck has no codes in the computer
Is there anyone on here that is in Southern California that would like to have their truck scanned with my tool so we could get a good baseline on the parameters?
97 Ford F250 4x4 Extra Cab Longbed Power Stroke (no mods) Front tow hitch, rebuilt E4OD at 162,000
Truck is up to 193,000 and counting as of 11-14-09
4stroke is offline
Old 11-17-2009, 11:55 PM   #19 (permalink)
4stroke's Avatar
Well I've got good new and Bad. The good news is I hooked my truck up to my friends OTC genesis scan tool and th IPR is reading 10% at idle and 15% KOEO. So there is nothing wrong electrical wrong with the truck. The bad news is I spent over 600 on a piece of junk matco scan tool. I'm hoping I can just update the tool to make it better but we'll see.
I'm having a code, I can't remember what number, but it has to do with exhaust backpressure valve range/ perform. Any insight on this?
4stroke is offline
Old 11-19-2009, 01:13 AM   #20 (permalink)
ccolby's Avatar
The back pressure sensor is the one to the left of high pressure oil pump (as you look at the engine from the bumper). You can see it as you look at the motor. It has two wires to it, with a tube that runs from the right exhaust manifold to the sensor. My truck has had this code for years.. Some day I'll worry about it. But the truck still runs strong. The tube gets plugged with soot from the exhaust system.
97 F-350,4wd,cc,long bed,4.10,35's,rebuilt E40D,H2E,3" intakes,Head studs,,pyrometer,boost,trans temp,home made open intake,Joe servo IDM, Inner cooler retro,Baby swamps 170/146, Bills 3 position chip,Updated HPOP, home made oil bypass filter system, A/C mod, updated super duty fuel system, 60 gal/toobox combo.
ccolby is offline
Old 11-19-2009, 01:19 AM   #21 (permalink)
ccolby's Avatar
You can try here if you find out that it's the computer..
Used 1997 FORD TRUCK F450 PICKUP Engine Brain Box - EverDrive Guaranteed Used Auto Parts
ccolby is offline
Old 11-20-2009, 12:05 AM   #22 (permalink)
4stroke's Avatar
Hi ccolby
Thanks for your responses.
I'm going to try and resnake that ebp tube.
I actually had jumped the gun and ran across that website in search of my computer. They did not have one. I did find one through a different source. But as stated there was nothing wrong with my PCM, it was the scan tool.
If anyone needs a F7TF-RC PCM let me know.
BTW
You may remember I met up with you one day and took a ride in your truck.
4stroke is offline
