intermittent failure - Diesel Forum - TheDieselStop.com
Old 01-11-2013, 10:37 PM   #1 (permalink)
reg
just in the recent days my '95 7.3L power stroke quits for a moment then kicks in and runs. this happens mostly at stop lights but has happened while at highway speed. any thoughts?
reg is offline   Reply With Quote
Old 01-12-2013, 07:28 AM   #2 (permalink)
S95
CPS sensor, get new before it quits permanently
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
S95 is offline   Reply With Quote
Old 01-12-2013, 01:26 PM   #3 (permalink)
blageurt's Avatar
My Photos: (9)
International ones are the best.....Avoid the grey "China " ones....
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Michelin LTX
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
blageurt is offline   Reply With Quote
Old 01-12-2013, 10:17 PM   #4 (permalink)
Does the WTS light come on when it comes back to life?
madpogue is offline   Reply With Quote
Old 01-13-2013, 03:38 PM   #5 (permalink)
flintshtr's Avatar
My truck in the signature had the same isuue, It turned out to be the wiring to the speed sensor on the rear housing. The wire is real crap and mune had numerous bad spots in it along with the plug. Hope this helps.
97 F-350-4X4-AUTO 355 GEARS--292,000+ MILES--ROSEWOOD STAGE 1 INJECTORS--SD HPOP--IDM MOD--BTS TRANS WITH SCHAEFER'S OIL --HYDROBOOST BRAKE SETUP-DPP DOWNPIPE--TS 6 POSITION CHIP--TYMAR INTAKE & HX MOD--HAYDON TRANS COOLER--FS 2500 BYPASS OIL FILTER--AMSOIL 5-30 OIL---EVANS COOLANT-203 STAT--WINDSTAR ELECTRIC FAN--DTRL--SYLVANIA SUPERSTAR BULBS- -ROYAL PURPLE SYNTHETIC IN BOTH REARS--WARN LOCKING HUBS--ISSPRO GAUGES IN AUTOMETER 3 GAUGE POD--XL CRUISE MOD--EXPLORER OVERHEAD CONSOLE-AC MOD--BILSTEIN SHOCKS--DB HT STARTER--WESTERN PLOW--CARGORAILS--NRA LIFE MEMBER--LIFE MEMBER SAFARI CLUB
1999 HARLEY DAVIDSON ROAD KING
1992 CONVERTABLE VETTE
2003 E-CLASS 4MATIC WAGON
67 RS/SS CAMARO
97 BMW 528I
flintshtr is offline   Reply With Quote
Old 01-14-2013, 09:25 AM   #6 (permalink)
reg
thanks all. CPS was replaced about 10 yrs ago with an International product. probably do it again.
Madpouge: what is the WTS sensor?
Flintshdr: interesting because i have been suffering with a "loss of contact" with that sensor causing a "confused" tranny where it gets into a hunting/searching mode (OD light blinking). i think i will do what i thought about for sometime and that is to replace the pair of wires to that sensor.
Old 01-14-2013, 10:49 AM   #7 (permalink)
blageurt's Avatar
My Photos: (9)
The wait to start light.....
Old 01-15-2013, 10:35 AM   #8 (permalink)
reg
duh! i do not think so. tell me about that one please.
Old 01-15-2013, 01:22 PM   #9 (permalink)
If the WTS light comes on after a failure while underway, it suggests an interruption in the main "key on" circuit to the PCM, the one energized by turning the key to RUN. Bad contact at the fuse (#22), wiring issue, connector at the bulkhead (firewall), ignition switch, etc; it's as if you turned the key back to OFF and the to RUN again briefly while going down the road.
If the WTS light doesn't accompany the failure/hesitation, then it's more likely the CPS or its wiring, or something fuel / injection or HP oil pressure related.
Old 01-16-2013, 09:37 AM   #10 (permalink)
reg
umderstood. thanks
Old 02-02-2013, 11:49 AM   #11 (permalink)
reg
problem solved
changed CPS with motorcraft part and now running well. thanks to all for your help.
