jb weld and fuel bowl - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-04-2008, 04:00 PM Thread Starter
Send a message via AIM to rockets10510
so my fuel bowl has several holes in the bottom. can you fill the bottom of the bowl up with JB weld?
also does diesel eat JB Weld?
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
post #2 of 7 (permalink) Old 12-04-2008, 04:35 PM
anthony
After cleaning it real well ,many have used J B..never heard anyone report back that it failed ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #3 of 7 (permalink) Old 12-04-2008, 08:05 PM
sloate's Avatar
jbwelded mine about 5000 miles ago with no problems
1995
F350, CrewCab, 7.3 PSD Dyno at 390 HP, zf5, 3 in Down pipe with 5in straight pipe with stack, Tymar, DDP stage 2 injectors, Intercooled, Stole it at $2500! 400000miles! Going for 1/2 million
1989
L8000 Dump Truck, 7.8L , 6 speed Fuller, 315000miles
1964
F350, 24v 5.9 Cummins, New Nv4500, Np205, JD green paint "Built Not Bought" 0 miles,
sloate is offline
post #4 of 7 (permalink) Old 12-05-2008, 08:19 AM
The JB weld will last longer than the fuel bowl. It does not rot out like the aluminum does.
Jeep1947 is offline
post #5 of 7 (permalink) Old 12-05-2008, 08:32 PM
Not to start a war or take anything away from JB Weld but,What about Lab metal? ( cause I have it readily available, On the shelf in my garage)
1996 F-350 psd crew drw, demuffed, fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />thanks Matt!! Stancor gpr (12/26/07) Coolant filter (11-1-2008) Relocated Block heater plug (1/01/2011) Tranni by JOHN WOOD (12-08-2009) Thanks JOHN more mods to come.
fordmedic is offline
post #6 of 7 (permalink) Old 12-05-2008, 10:36 PM
farnereinar's Avatar
My Photos: (6)
i just ordered some high heat lab metal up, has a much higher heat range than jb, altho i dont see it getting to be over 650 degrees in the filter bowl
i need mine for a small exhaust pinhole i made when welding nearby
and maybe.....to avoid getting those bellowed turbo uppipes...not sure how i feel about gooping that stuff all over my exhaust doughnuts though
daily: 2002 f350 crew cab long bed 7.3l 4x4 auto lariat 320k latest mileage edge juice (i mean edge trans killer) 9' arctic plow
work: Peeeeterbilt 357 triaxle dump 19.5' EAST body air ride 18speed n14 cummins 470hp mechanical
plow stakebody: 1995 F-superduty 2x4 7.3L Dump e40d, heavy and slow
1985 F-350 Diesel 6.9 4x4 Reg Cab SRW c-6 automatic connected to a borg-werner 1345 TC, 4:10 posi d-50 front and sterling 10.25 rear, TTB, A/C, new springs, shocks, starter, 450amp alternator new floors rockers wheel wells, doors, hood, fenders & black paint
accident in feb. 2006 left her totaled, but will be re-bent to perfection in time.
dads: 1992 non-turbo 7.3 e4od 4x4 extended cab 3.73rears 265k miles, runs like crap, looks like an angry cloud.
farnereinar is offline
post #7 of 7 (permalink) Old 12-05-2008, 10:47 PM
You can thicken it by leaving a little bit out to dry out. I use a tongue depressor from work. You can also get them from any craft store.
