Just installed the engine, and I can't get fuel to the engine
The engine has been out of my truck for a year and I installed it. The engine was pulled to replace the rear main seal. I have been trying to start it, but there seems to be no fuel pumping. I tried filling up the oil pump resivior with oil because I heard that this may stop the engine from running if it is empty. There is no white smoke coming out of the exhaust when I am cranking on the engine. I am new to the DI crowd, my last truck was a 6.9. Does anyone have any suggestions or ideas why the truck wouldn't be pumping fuel, or how I can get this SOB running?
94-1/2 F350 Dana 60 strait axle 4.88 spooled, 14-bolt 10.5 4.88 detroit with disk brake conversion, 6" suspention, 5-speed, Banks intercooler, straightpipe, NP 205 T-case, 1410 U-Joints & Yokes, 40/13.50r18 ProComp X-Terrains, Bullydog Chip & injectors, Centerforce Stage 3 clutch, Flex-a-Lite Aluminum Diamondplate electric fan, water methanol, Bedlinered paintjob, blows the black smoke, etc... OUTLAWZ 4 LIFE!!!
Just thinking out loud: Do you hear the fuel pump pumping with the key on? If not, maybe the fuse is burnt up for the fuel pump. The other thing I thought of was the emergency fuel switch up by the passengers outbound floor panel. Not sure if yours would have it or not, but if it does, it's possible that manhandling the engine out of there caused the switch to pop. It is resettable, if you have one up there.
Is the fuel bowl filling up at all? Are you getting power to the fuel pump at all? Maybe there's lots of air that needs to be purged? Or, maybe the fuel pump was questionable before the engine overhaul, but it is finally toast now?
How strong are the batteries? It takes some good, fresh batteries to get these puppies started.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
The OBS trucks have a mechanical pump in the valley, so you won't hear any pump running unless someone upgraded to the electric pump, which some have done on them.
I would say pull the fuel bowl lid, and see if there is fuel in there. If not, crank while the lids off and see if it fills up. If not then,, well that's fairly obvious aint it? LOL.....
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
Since the in-valley fuel pump sucks all the way from the tank, you have to be absolutley sure there isn't a leak in the line allowing air in. If there's air in the pump, it compresses and will pump LOTS LESS volume.
You could try putting a little pressure on the tank with a shop vac and rag seal at the fill nozzle and see if you can get the pump primed.
This sounds like a good Idea. Im gonna try to pressurize the system, because after severe cranking, when I hit the purge there is the smallest plunk of air that comes out. I also forgot to mention that this thing is an Ambulance package.
I am getting fuel pressure now, but the damb thing still won't start. If I spray some starting fluid into the air intake, it starts, but not even long enough to idle. Is there some way that you have to bleed the injectors or something?
Did you verify there is fuel in the filter bowl on top of the engine ? If not, pour it full and crank again to see if it'll start.
I like BIG, LOUD, heavy trucks, light, tiny women, shooting, and BIG glasses of heavy beer (not necessarily in that order, either ). http://www.youtube.com/watch?v=-TC2xTCb_GU
The little gal I bought my truck from called it her "COWGIRL HARDWARE".
I call it "LURCH" !
96 F250 4WD, 35 INCH TIRES over a inch lift kit, DUAL 5 INCH STACKS (sounds pretty darn good), BLACKed OUT WINDOWS, SNOW PLOW
CENTRAL OHIO
Indirectly, to "bleed" the hpo supply to the injectors, there are a series of plugs in each head where the hpo feed lines connect. Remove a plug on one head and crank until you see oil flow, then plug, move onto the other head and repeat. When you see oil flow, the galleys, lines, hpor and hpop are full. Keep an eye on the hpor and refill as required.
Do you see rpm while cranking?
You have verified fuel pressure.
Keep batts charged up. Give your starter a break.
Be careful with the starting fluid...
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
I am going to check those plugs on the heads to make sure that there is oil flowing. The HPOP is full. It is cranking around 250-275 RPMs. I don't like using the starting fluid, but at least it helped me hear this thing come to life for once.....
When oil flows, and if no start, unplug the icp and crank.
Randy
I am getting 40 psi on the fuel pressure when I am cranking on the engine. Could the injectors not be firing for some reason?
No smoke, no injector fire. As stated by STurbo, check all connections. We know cps is plugged in because you have indicated rpm. Unplug ipr and check at the connector for 12vdc. By disconnecting the icp, the pcm defaults ipr to a high % duty cycle.
Do you have oil flow from the ports in each head?
Randy
