key in ig switch chime - Diesel Forum - TheDieselStop.com
Old 05-24-2005, 07:05 AM   #1 (permalink)
Will i hurt anything if i disconnect that wiring harness thats on the buzzer for the key in the ignition? Ive disconected it before on other vehicles but they didnt have all the wires runnin to it that this does.
my photos
95 f-250 444e e4od 4X4 ex cab long bed 3.55ls White Knight Reverse Lights, AIC, FORD seatcovers, AFE STAGE2 INTAKE, 3" downpipe 4" exhuast, EDGE Evolution 100hp setting, auto meter ultra lite pyro, tranny and boost gauges, .177bb in FPR, amsoil atf in transmission & tcase, amsoil syn gear lube in rear diff, bilstien shocks, fog lights, 1000cca batteries
************future mods*******************
intercooler, smaller turbo housing, window tinting
03 vw jetta tdi stock for now
traxmedic is offline
Old 05-24-2005, 07:30 AM   #2 (permalink)
Re: key in ig switch chime
I just pulled the plug on my 97 F-250 and it didn't cause any problems. I may try to isolate the circuit that rings the bell if you leave the headlights on. That warning bell is usefull. The door open with the key on warning and the seatbelt warning are just annoying. ( I buckle up regardless)
1995 Super Duty W/ 8 ft. dump, 7.3PS, home made open element air filter
1997 F-250 Reg. Cab Longbed P/U, 7.3PS, Home made open element air filter
Ralf is offline
Old 05-24-2005, 07:45 AM   #3 (permalink)
You can go to the plug for the warning chime and cut the Black/Pink wire going to it and the "key in ignition" warning will be silenced, unless they've changed the color code since 1990. As Ralf said, the "lights on" warning is useful and the rest of them don't really bother me. Put quick connect ends on the wires if you wish and then you can reconnect if and when you decide to sell.
'90 F-450 SD, 7.3L IDI DSL, ZF-5 spd manual, 2wd, 11" x 10 spline clutch, 2-wd, contractors 10' dump box, standard cab, bench seat, Dana 80 rear w/4.63:1 gears, 174" wheel base (need lotsa room to turn),weighs in at a little over 9000, no frills.
'96 F-250 PSD standard cab, 2wd, E4OD, 328K on the clock.
daniel45 is offline
Old 05-24-2005, 08:48 AM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I just pulled that little black box out of there and winged itinthe trash.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 05-24-2005, 11:51 AM   #5 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
i pulled mine out too....but i ran it over with the truck instead [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
-Dan
1997 F-350 PSD, Cali Truck, 165k, 4x4, Reg Cab, LB, 4.10's, Auto, Sandpiper Diesel Performance 4" Exhaust, DIY Open Intake, Autometer Gauges, TS 6 pos Chip...more to come.
#24
PSDan000 is offline
Old 05-24-2005, 12:03 PM   #6 (permalink)
My Photos: (27)
That's pretty much what I did, but I put a switch inbetween so if I'm working on the truck or whatever, I can flip the switch and turn it off. Does not affect the light chime and when I want it back (I'm such a space cadet @ 27), I just flip it back.
A diagram is in my pics. A link to my pic is in the sig.
JB
1997 (Built 2/97 Ours since 2/02) F-250 HD Ext Cab XLT
PSD, TDE1, LWB, Auto, 4.10, 4x4, Manual Hubs, Overloads, White Century Topper
Mods: GP and Door Chime Bypasses , DPPI Downpipe, Bilsteins, Autometer Z-Series (Pyro, Tranny Temp, Boost) in Rockin S Pod, Tymar Intake and Coolant Filter, Tru-Cool Trans Cooler, Magnefine Trans Filter
TDS Mods: Gutterguarded Grill, <$10 Cold Air Intake, FPR Shimmed @ 70psi
JazzBass is offline
Old 05-24-2005, 01:26 PM   #7 (permalink)
Thanks for clarifin it. I had one in my 85 and it kinda fell out by accident.
my photos
Old 05-24-2005, 01:52 PM   #8 (permalink)
Renegade's Avatar
My Photos: (28)
Send a message via ICQ to Renegade
I killed the key in dinger with a small strip of black tape by pulling out the switch & putting it on the side contact area & putting the key switch back in.
That way the if the lights are left on it will still make racket to let you know.
Cheers
Brian
95 F-250 XLT,SC,4x4,TDE1,LWB,4:56's,Dana 60,E4OD(lightly tuned),Tymared,Swamped,Lifted,rear disc brakes,6 pos chipped & a pile of other odd & end mods.Trucks,Parts & Misc. Pics 05 F250 V10 too
Renegade is offline
Old 05-24-2005, 03:08 PM   #9 (permalink)
Allright guys......I have tried to find mine little dinger box, but cant. Baz says its up under the center of the dash on the left side..............I cant find the dang thing. Mine goes off without the key in the ignition, and whenever else it wants to. Any ideas?
Kevin
Michigan Powerstroke Association
www.tsperformance.com
"Cowboy Up Or Stay In The Truck"
Farm Truck = Cowboy Cadillac
95 F350 Extended Cab Dually Long Box, 2 Wheel Drive, No Muffler, DIY Tymar intake, Cali Shim Kit, HX Mod, Ford AIC, Reese/5th Wheel/Gooseneck Hitches, Cobra CB/Dual 4' Valor Antennas On Diamondplate Toolbox, Pioneer Component CD System, Brake Controller, Cool-Down Timer
Toy Truck = Danger Ranger
1983 Ranger 4x4, 35 Super Swampers, Fresh 390 Big Block, Dana 44, Ford 9, Trailer Queen = Not Street Legal
bigdraft is offline
Old 05-24-2005, 06:04 PM   #10 (permalink)
its just a lil black box with a bunch of wires going to it. next time the lil guy is makin noise just listen and follow the noise.
my photos
Old 05-24-2005, 10:26 PM   #11 (permalink)
PSDan000's Avatar
My Photos: (11)
mine was a grey box...not black. might want to look for that
-Dan
#24
PSDan000 is offline
Old 05-24-2005, 11:08 PM   #12 (permalink)
My Photos: (44)
Here is a picture of mine, I removed the keyless entry module where I could take a picture of it, it is right behind the little kubby hole (recess) in the dash, just to the right of the steering wheele, you can just pull the plug off the box and leave it mounted if you want.
http://community.webshots.com/photo/...06717809tLehkZ
Thanks,
Bill Miller.
dreamachinef250 is offline
