Keyless entry ?? - Diesel Forum - TheDieselStop.com
post #1 of 33 (permalink) Old 12-09-2007, 12:02 PM Thread Starter
Excavator's Avatar
My Photos: (11)
Keyless entry ??
Hi all [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
While under my dash in my 96 F250 stroke I was hooking up my trailer brake controller and found a box which says "KEYLESS REMOTE ENTRY" Any one know what I can do to get a remote to function with this thing. I will take a closer look to see if any numbers are on this thing.
Also where do I find a keyless fob that would work?
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #2 of 33 (permalink) Old 12-09-2007, 01:05 PM
My Photos: (12)
re: Keyless entry ??
car stereo shops are pretty good with that stuff
86f2504x4,6.9, hypermax turbo, cowl induction, 3.5 hypermax exhaust, c6 3.55 std cab
97 f250 psd 4x4 ex cab, auto 4.10ls wildman tunes
rthomas is offline
post #3 of 33 (permalink) Old 12-09-2007, 01:23 PM
banjodog's Avatar
You can usually find the remotes on eBay. Here's what Ford has to say about them:
Section 01-14B: Door Lock Control System, Electronic 1997 F-250/350/Super Duty Workshop Manual
DESCRIPTION AND OPERATION Procedure revision date: 05/17/2000
Programming, Electronic Door Lock Control System
NOTE: The remote entry features will not function when the key is in the RUN or ACCESSORY position.
NOTE: The remote entry receiver module erases all previous transmitters from memory when the transmitters are programmed or reprogrammed. The remote entry receiver module can store up to four transmitters in memory.
To program (or reprogram) transmitter(s) into the remote entry receiver module, perform the following steps:
Turn key to the ON or ON/ACCESSORY position and momentarily short the two terminals of the program connector (C4) (a two-pin connector taped to the wire assembly connected to the remote entry receiver module, approximately 6 inches from the remote entry receiver module). All doors should lock then unlock. Remove shorting pin.
Press any button on transmitter. All doors should lock then unlock to verify that the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter).
Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
Key off. All doors should lock then unlock.
Check operation.
'97 CC F350 PSD. 4x4. Auto. Black. Wildman 6pos Chip! BB in FPR. KCM HPX from ITP. 3"DP. AFE intake. 3.55's. BFG MT KM2 315/75/16's. Reunel Front and Rear Bumpers. Ford AIC module. Warn HD manual hubs. AutoMeter Z-series gauges on the pilar. <span style="color: red">((Sky RSK w/SD springs and bilsteins waiting in the living room))</span>
banjodog is offline
post #4 of 33 (permalink) Old 12-09-2007, 01:30 PM Thread Starter
Excavator's Avatar
My Photos: (11)
looks like I just need to pick up a few remotes for F250 and program them
Here is what mine look like looks just like this one
Swamps,Tony Wildman
post #5 of 33 (permalink) Old 12-09-2007, 01:44 PM
banjodog's Avatar
You can use any of them from the 250 350 or 150. I think they may even be the same as Bronco and explorer. Don't know about the cars.
banjodog is offline
post #6 of 33 (permalink) Old 12-10-2007, 07:44 AM
did all xlt's have remote entry or was it only a select few?
1997 Ford F-350 XL 4x4 Powerstroke Diesel
1997 Ford F-250 HD XLT 4x4 Powerstroke Diesel, Tymar intake, Stancor GPR
1995 Ford F-350 XL 4x4 Powerstroke Diesel, 5 Speed, Dually, Tymar intake
lewis8820 is offline
post #7 of 33 (permalink) Old 12-10-2007, 07:51 AM
BlueMule's Avatar
My Photos: (12)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: lewis8820</div><div class="ubbcode-body">did all xlt's have remote entry or was it only a select few? </div></div>
Not all xlt's had it, my 97 did and the 96 doesn't.
Rodney#33
BlueMule is offline
post #8 of 33 (permalink) Old 12-10-2007, 07:56 AM Thread Starter
Excavator's Avatar
My Photos: (11)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BlueMule</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: lewis8820</div><div class="ubbcode-body">did all xlt's have remote entry or was it only a select few? </div></div>
Not all xlt's had it, my 97 did and the 96 doesn't. </div></div>
Mine has the box for it, must have been orderd as option.
I just need a remote now and program it
Swamps,Tony Wildman
post #9 of 33 (permalink) Old 12-10-2007, 08:48 AM
BlueMule's Avatar
My Photos: (12)
Jim
Ford used the same remote for a number of different vehicles. 94-97 "F" series, 92-98 "E" series, 94-96 Bronco, 94-97 Ranger, 93-97 Explorer and Mercury Mountaineer, 95-96 Windstar and 93-97 Probe. There are a bunch of them on ebay.
Rodney#33
BlueMule is offline
post #10 of 33 (permalink) Old 12-10-2007, 12:44 PM Thread Starter
Excavator's Avatar
My Photos: (11)
thanks Rodney, just bought on on Ebay [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Swamps,Tony Wildman
post #11 of 33 (permalink) Old 12-10-2007, 01:17 PM
where is the box located?
post #12 of 33 (permalink) Old 12-10-2007, 01:29 PM
banjodog's Avatar
Under the dash just to the right of the steering column down low.
banjodog is offline
post #13 of 33 (permalink) Old 12-10-2007, 01:39 PM Thread Starter
Excavator's Avatar
My Photos: (11)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: lewis8820</div><div class="ubbcode-body">where is the box located? </div></div>
here is pic / says attention
LOOK
Swamps,Tony Wildman
post #14 of 33 (permalink) Old 12-10-2007, 06:45 PM
JDrescher's Avatar
i have the remote keyless entry and i bought new batterys for it and it still doesn't work should i try to reprogram it?? any pics of the shorting pin or how you do it thanks
-Jeff-
Home of the Tekonsha Brake controllers
96 F-350 PSD~4x4~Reg cab~SRW~E4OD~ 233,000~3.55~Dominator 66~E99 spyder with 7.3 SD intercooler~DP Tuner F5 stock,hi idle,60tow,60econ,80econ,120race,140,lope idle~BTS trans~BTS custom trans cooler setup~RDS Stage 1 injectors~Labonte Water-Meth kit~upgraded downpipe~4in straight exhuast~EBPV into exhuast brake~Tymar intake~Tymar HPX line~FPR mod~boost,trans and pyro guages
adrenalin HPOP and modded IDM are up next!!
89 F-250~4x4~Reg cab~7.3 IDI~ZF 5 speed~6 in stacks~155,000~(My beater)
JDrescher is offline
post #15 of 33 (permalink) Old 12-10-2007, 06:50 PM Thread Starter
Excavator's Avatar
My Photos: (11)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JDiesel350</div><div class="ubbcode-body">i have the remote keyless entry and i bought new batterys for it and it still doesn't work should i try to reprogram it?? any pics of the shorting pin or how you do it thanks </div></div>
Here is the plug and you just turn on key and touch to pins to short and locks will click, then hut the button on remote. Turn off key to finish
Grey plug
Swamps,Tony Wildman
