Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-22-2006, 11:42 PM   #1 (permalink)
My Photos: (11)
Keyless entry doesnt work
A few months ago my keyless entry got to the point that I would need to push the button more than once to get the doors unlocked. I figured that it was probably the battery. It would sometimes just off while I was in the house and when it did it was hell getting it to stop. I decided to just take the fuse out that and said the heck with it. Now I dont have a door key so I would like to get it going again. Now even with new batteries nothing happens when I press the buttons. How can I tell if the remote is the problem or where do I begin trouble shooting?
1995 F-350 DRW Supercab 7.3 Turbo 5spd
Mozz is offline
Old 07-23-2006, 01:01 AM   #2 (permalink)
Re: Keyless entry doesnt work
not trying to be a smartass (in the donkey term), but did you put the fuse back in that you took out?
I am sure your more truck smart than I am, but I find myself in those situations more often than not. Most be old age creepin up on me [img]/ubbthreads/images/graemlins/frown.gif[/img]
Sonny
2006 4 door swb dodge cummins all stock
* SOLD * 1997 F-250 PSD Ex-Cab 4x4
280,000 miles
4" lift - 35" BFG AT , Vault keyless entry,
3" Performance Parts DP w/CAT & muff delete,
FPR shim
May God be a Presence in Your Everyday
crfinc is offline
Old 07-23-2006, 11:21 AM   #3 (permalink)
Could be the door actuators going bad? You don't have a problem opening it up w/ a key do you? OR you need a new keyfob.
I'm currently having the same problem after getting my keyfob wet on my 01, and those seem to be the general responses I come up with.
Also about the fuse... 2nd that.
2001 F250 Platinum Edition
Hybrids, 38R, Studs, Springs, Forged, etc...
13.6 @ 100 @ 7600 lbs on #2 only
Maintain is offline
Old 07-23-2006, 02:28 PM   #4 (permalink)
Ragdude's Avatar
You have a seperate key for your door? I thought they had done away with that by '95. On my '80, I had the key ground on one side for the door and the other side for the ignition. (to make the best of a bad situation).
But I would guess the fob is your culprit. Or, if you hit the unlock button twice, do any other doors unlock? In that case it would be your actuator on the drivers door.
Protect the 2nd Amendment!
It's the original homeland security act.
'96 F350,Dually,CC,5 spd.,stock.
B100 baby! Bring it home, to the American farmers!
Ragdude is offline
Old 07-23-2006, 10:12 PM   #5 (permalink)
Had the exact same problem on a friends 95'. On his it was the keyless entry's control module, located under the dash right in the middle. Might be your problem?????
doby86 is offline
Old 07-23-2006, 11:15 PM   #6 (permalink)
My Photos: (11)
LOL! No the fuse is in and the anti theft light on the dash works so I am pretty sure that its armed. The power door locks work if that means anything.
Mozz is offline
Old 07-23-2006, 11:17 PM   #7 (permalink)
My Photos: (11)
Same key does the door and the ignition, problem is that the key is broke off in the ignition. Whats a fob? Im thinking its probably the remote but I have no way of knowing if its emiting a signal or not.
Mozz is offline
Old 07-24-2006, 02:28 AM   #8 (permalink)
PSDfreak's Avatar
fob is the remote...I am having some trouble with mine too...I have to be real close to the truck to lock/unlock...
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 07-25-2006, 04:39 AM   #9 (permalink)
My Photos: (6)
Sounds like your battery (in the fob)is weak. Signal strength goes down as battery gets weak, which cuts down on the distance it'll work.
'95 XL SuperCab, LWB, 4X4, 204,000 miles, E4OD, 4.10 LS(when it wants to be!), body lift, 305-70-16 Cooper STT's on 10" Eagle Alloy wheels, "Brand X"-inspired home-made open-element air filter, 3" downpipe & 4" straight pipe with 5" stainless tip exiting in front of the rear wheel, 6 pos. TS Performance chip (going to visit T. Wildman soon, I hope), FPR mod, A/C mod, MileMarker manuals, onboard air (York running off the alternator...1 five gallon tank) with dual Grover air horns
2000 Jeep Wrangler Sahara Edition, white w/tan top & interier, 119,000 miles, 4.0L, auto, loaded.....no mods, yet!
Knothead is offline
Old 07-26-2006, 09:21 PM   #10 (permalink)
PSDfreak's Avatar
I have three FOBs...JUST changed the batteries in all three with brand new ones and all three still have the same range (have to be close to truck)
-casey
PSDfreak is offline
Old 07-27-2006, 02:35 PM   #11 (permalink)
My Photos: (11)
Mine doesnt work even if im in the truck. Im not sure how to tell what batterie works with mine. Ford says they dont know either
Mozz is offline
Old 07-27-2006, 10:02 PM   #12 (permalink)
how long has the key been broke off in the ignition, I wonder if that has anything to do with the fobs not working?
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/
My Truck [/b]
<font color="red">2004/1997 Powerstroke Pics, Ford 9N Tractor,</font>6.0 Bible<font color="blue">
dwelch1 is offline
Old 07-27-2006, 10:13 PM   #13 (permalink)
My Photos: (11)
A long time. It worked back a few months ago but it got weaker and weaker along with that the damn thing would just go off sometimes so I pulled the fuse. Now I would like for it to work again but it doesnt. The power doors work and the theft light come on. Can you program a fob from another keyless product to work with mine? My grandfather has two new fobs that he doesnt use.
Mozz is offline
Old 07-28-2006, 01:14 PM   #14 (permalink)
Mozz ... here is a question. How many fobs do you have? If it's only one are you sure it's the original.
to answer you question above the answer is yes. A good rule of thumb is to look at the fob at the FCC # if it matches your good. Some will work even though the FCC # doesn't match.
You can always put your keyless in program mode and try to add the fob or fobs you have back to it.
If you need to know how : ( do this with the doors shut and all locks up.
1. cycle the key from off to on 7 times leaving it in the on position on the 7th.
2. If your keyless module is working right it should cycle the door locks down then up.
3. this lets you know the module is ready to receive a new fob signal. Press the lock button on your fob. If the module is receiving a signal it'll cycle the locks again.
4. press the lock button on all additional fobs you have. I'm not sure on the limit on the old ones. It's either 4 or 7 can't remember.
5. when you're done. Turn off the ignition.
If the locks don't cycle when you press your fob button something is not working right. Hope this helps.
1997 F250 2wd Crew Cab, Auto. Mods: New Katzkin seats, Home made Tymar, 3" DP, Kitty ran away, New Tranny, & Fuel pressure gauge.
2004 Excursion 6.0L Limited ( wifes ) BullyDog Tripple Dog downloader w/ Outlook Monitor, Banks Intercooler, Banks Monster Exhaust, Volant air intake, zoodad mod, & added pusher fan to a/c condensor.
brians1997crew is offline
Old 07-07-2008, 10:15 PM   #15 (permalink)
i did this anf the after the 7th time the locks went up and down i push the reomote and nothing happens/????????
F250 Pwerstroke 4X4 Crew Cab Short Bed
jrock914 is offline
