Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 11-06-2009, 09:48 PM   #1 (permalink)
Leaking oil from plug on Passenger side block.
Why is there a plug there, what is it for, and has anybody else had this and what's required to stop the leaking?
Thanks.
97 F-250 Crewcab,4X4, 4.10 gears, coolant filter, 203 deg. thermostat, coolant eye, Bilsteins, 255/85R16s.
00 Ural BC-65.
97 Honda Foreman.
"A little rebellion, now and then, is a good thing." Thomas Jefferson
pigdog is offline
Old 11-06-2009, 10:12 PM   #2 (permalink)
Supporting Member
bugman's Avatar
My Photos: (16)
If you are talking about the plug on each end of the cylinder head it is to drain the oil from the high pressure oil galleries in the head. So if that is leaking you can pick up a new plug and O ring kit from the dealer to replace it.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is online now
Old 11-07-2009, 02:26 AM   #3 (permalink)
Jcart's Avatar
If that is the leaking plug, which is not uncommon use a 3/8" drive to get it out and new one in.....some long extensions help, can't remember if you have to pull an up-pipe or the DP to get at it though....
jrc
97 XLT F250 CC E40D 355's T Wildman programs, CCV mod, TDS exhaust brake, downpipe 4" exhaust, custom SS resonator, SD springs front and Rear RSK, Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, 'jectors, SD Hpop, DIY electric fans, VisionX HID's
http://community.webshots.com/user/jcart44
Jcart is offline
Old 11-12-2009, 04:39 PM   #4 (permalink)
The plug I'm talking about is just above the starter, you can see it if you look in the passenger front wheel well, you can see it between the frame, just below the header.
00 Ural BC-65.
97 Honda Foreman.
pigdog is offline
Old 11-12-2009, 06:22 PM   #5 (permalink)
You may be talking about the oil galley drain plug. They are pipe threads, just tighten up. If that doesnt do it, back the plug out and reinstall with pipe dope on the threads.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 11-12-2009, 07:00 PM   #6 (permalink)
midwestconnection's Avatar
There is a coolant plug that is also located in the end of the head that is 1/2 and has a 3/8 pocket for a ratchet to take it out. It's at the drivers side rear, just below the bottom corner of the valve cover. There is also the same thing in the front corner, passenger side.
Bumper to bumper, Full Synthetic!!! Rotella T 5-40 -- Mobil 1 Mercon V -- Amsoil Extreme 75-90 -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 15 Passenger Van with E40D and Dana 60. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
Old 11-12-2009, 07:28 PM   #7 (permalink)
This just went out on my 7.3. If is the plug that holds the dipstick it could get ugly. There is a large 'o' ring on the inside of the pan; if it fails you will be pumping oil out through the seal. International Harvester sells a kit to repair this in without pulling the motor. I tried, dropped the piece and OUCH! the motor had to come out. Some other kind soul posted step by step color photos with the International part number and infor if your are interested let me know.
GentlemanJack is offline
Old 11-12-2009, 08:54 PM   #8 (permalink)
pjwoolw's Avatar
My Photos: (5)
Powerstrokehelp.com has a video on the replacement of the pan o ring. At least some good tips.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 XLT 4X4 Gone but not forgotten
pjwoolw is offline
