Little help please- dropping front fuel tank - Diesel Forum - TheDieselStop.com
Old 10-27-2009, 03:40 PM   #1 (permalink)
Question Little help please- dropping front fuel tank
I have a leak in my front fuel tank. I have the skid plate off and the straps ready to come down. Before I go any further I have these questions:
1.) Do the two fuel line connection devices just push off to separate them from the tank?
2.) Is the wire connection a simply disconnect?
3.) Are tanks repairable?
4.) Any not so obvious info that I would need to know about removal and reinstall considering I'm a software developer and not a mechanic?
97 F250 XLT HD Supercab, LB, 7.3 Turbo Diesel, Auto Trans(E40D), 4WD, 4.10, Stock, took it over at 190,000 mi.
New GPR, T-stat, new Torque Converter, rebuilt steering column, front pads/rotors, new rims, outer 4WD u-joints, both GP wire harnesses, glow plugs, valve adjustment, rear shoes and drums, 3 engine pulleys, upper & lower ball joints, theft deterrent device.
newrig is offline
Old 10-27-2009, 05:51 PM   #2 (permalink)
They use a spring-loaded quick-disconnect. A special fuel-line tool is required (about $5 at Autozone or similar stores). Sometimes crud can build up behind the spring clips, making it hard to get the tool fully inserted. Shooting some brake cleaner into the joint should be sufficient to soften and dislodge said crud.
Yes. The connector is usually mounted up to the frame, about a foot from the sending unit.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 10-27-2009, 05:59 PM   #3 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
I've used JB Weld to repair fuel tanks before. But I recommend replacing the tank for peace of mind. I bought the front one for my old '95 for 125 bucks (Canadian).
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
fordsforever73 is offline
Old 10-27-2009, 08:52 PM   #4 (permalink)
Thanks for the info. I probably would have busted it off not knowing it needs a tool. Same with the wire - I figured it disconnected at the tank somehow - I couldn't really see up there very well. Thanks again because I was just about to go out and try to take it down.
newrig is offline
Old 10-27-2009, 09:52 PM   #5 (permalink)
Exclamation
Do you know where the leak is coming from, mine was leaking and the clamp of the big hose was a little loose, I tighted it and no more leaks. Just a thougth.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 10-28-2009, 10:24 AM   #6 (permalink)
Mine appears to be leaking at the top under the front strap. It only leaks about a gallon or two when I fill it up all the way. Dealer want's $525.00 new so I hope I can JB Weld it or I'll look after market or salvage.
newrig is offline
Old 10-28-2009, 11:49 AM   #7 (permalink)
Arrow
Well, mine only leaked when I filled it up, but not that much quantity. Maybe you have another part that its leaking.
