Little white hose - Diesel Forum - TheDieselStop.com
Old 11-15-2009, 11:35 PM   #1 (permalink)
Little white hose
Just looking today and saw that the little white hose to the air canister?under the hood was rotted out. Of course it was in 2 pieces. It goes into a loom. Where does this go so I can replace it?
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
Old 11-16-2009, 12:06 AM   #2 (permalink)
realbadlarry's Avatar
Just peel the loom back till you get to good white hose, put some silicone on the white hose like 1/2" up from the end, slide some 1/8" rubber hose on it, then attach the other end of the rubber hose to the actuator the white hose rotted off of. Defaults the ac to defrost if the line is broken.
95 CCLB 4X4, DP, TYMAR, Adeneline HPOP, 5POS CHIP, 4",3 GUAGE POD, 129k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.Banks IC
realbadlarry is offline
Old 11-18-2009, 12:07 AM   #3 (permalink)
Sounds like a plan, thanks.
