Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-06-2008, 04:23 PM   #1 (permalink)
location of sensor
I have tried to do the search but with no results. I am trying to find out the location of the sensor that has to do with the altitude the truck runs fine when at higher altitudes but at about 1000 slugish and depresing. any help would be accepted. thanks
97 F350 crew cab 4x4 mostly stock but I'll fix that in time, 4 inch exaust by jardin, filter housing by afe
WyomingPSD is offline
Old 07-06-2008, 05:16 PM   #2 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
EBP sensor, Exhaust BackPressure sensor. If you look down on your motor with the engine cover removed, theres a black metal plate just above and a tiny bit behind the HPOP reservoir. It is bolted to that plate and theres a tube that runs to it from underneath the plate. It is a 3 wire sensor. The plug is vertical...meaning the pins that it plug into go straight up and down.
Theres also a BARO sensor. Im not sure where its located though
1994 F-250 PSD, 280+k and still strong, 2wd, zf5 close-ratio, 4.10 rear, Tymar intake, Valeo SMF, 205* T-stat, DIY Aux idle control,shot the cat, dual trucker antennas, 5600 pounds, matching autometer ultra lite boost and pyro. DIY stage 1's, ts 6 pos chip (stock anti-theft 50 75 100 140), excursion HFCM fuel pump on its way
Nicknamed the american bear
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
91diesel is offline
Old 07-06-2008, 05:32 PM   #3 (permalink)
STurbo90's Avatar
My Photos: (9)
the baro sensor is inside the cab above the accelerator pedal, looks like a relay. it is mounted on a metal tab.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 07-07-2008, 08:34 AM   #4 (permalink)
thanks i will check these out would be nice to have the old gal running like she should
Old 07-07-2008, 02:37 PM   #5 (permalink)
HERE is the EBP sensor
EBPSensor pictures from cars photos on webshots
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; gutted Kitty; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 07-07-2008, 02:39 PM   #6 (permalink)
Exclamation
I havent heard about this sensor, do you have any pic?, I thougth was like the MAP sensor
Old 07-07-2008, 10:43 PM   #7 (permalink)
STurbo90's Avatar
My Photos: (9)
I don't have a direct pic of it, but if you look at this pic,
OEM keyless module pictures from cars photos on webshots
it is the black square box that is held up by the white plastic clip, closest to the steering column.
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 07-08-2008, 12:00 PM   #8 (permalink)
Thumbs up
First of all THANK YOU, but is the black square box with a white label, pretty similar in size to the OEM keyless module, that is partialy visible in the left part of the pic, and close to a grey connector? because I cant see the white plastic clip.
Old 07-08-2008, 03:12 PM   #9 (permalink)
STurbo90's Avatar
My Photos: (9)
I'm not sure what white label you mean?
I circled the sensor in this pic,
Baro sensor pictures from cars photos on webshots
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 07-08-2008, 03:14 PM   #10 (permalink)
The MAP sensor is what would change with altitude.
I highly doubt that the EBP has anything to do with altitude. Pressure it senses is completely dependant on RPMs, boost, etc which would override and barometric pressure changes.
Snowtow is offline
Old 07-08-2008, 03:22 PM   #11 (permalink)
Talking
Ahh, Ok, I thougth it was the "grey connector" I mentioned, the other with white label is partially seen to the right part of the pic and little above of the sensor you circled.
Thanks a lot.
