lock out hubs - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 11-14-2005, 11:36 AM Thread Starter
lock out hubs
I have a 1996 f-350 axle, and one of my lock outs went bad. Ford wants $180 for one hub. I can get a set of warn lock outs for $190. any input is appreciated on what brand or good places to buy.
Justin
1993 f-350 4x4 5speed 277,000 banks turbo,3in body, 4" superlift and 35'' bfg mud terrain
justinwiseman is offline
post #2 of 18 (permalink) Old 11-14-2005, 11:40 AM
Re: lock out hubs
Justin,
I think Warn makes a good hub, but I think Ford hubs are made by Warn. I could be wrong, but I believe I read that somewhere [img]/ubbthreads/images/graemlins/phoney.gif[/img]
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #3 of 18 (permalink) Old 11-14-2005, 11:42 AM
Re: lock out hubs
The ford hubs are junk, I went through one the first couple of days i had the truck. I've been very happy with my warns. Plus ford makes theirs out of plastic, warn makes theirs out of metal. I bought mine from 4 wheel parts.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by
, Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
TimMiller is offline
post #4 of 18 (permalink) Old 11-14-2005, 01:01 PM
PSDfreak's Avatar
Re: lock out hubs
Yes I believe the manual ford lockouts ARE made by Warn, and as I understand it, they are pretty strong too. The knob is plastic but I dont think that affects the way it locks? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Never had a problem with mine...
Warn makes a very good hub, had them on my last truck, never a problem. I would replace with warn.
Godd Luck,
Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #5 of 18 (permalink) Old 11-14-2005, 01:28 PM
Re: lock out hubs
My factory Ford hubs are metal. I would not call them junk considering the severe (major understatement) abuse and mileage I have on mine. I dont think the Ford hubs are made by Warn as all Warn hubs I have or have used are a full 360* turn to lock. Ford is 1/4 turn. Interestingly Superwinch hubs are also 1/4 turn and very similar.
The only Ford hub I've heard was junk is the auto lock. Everyone I know who had them replaced with the Ford manual lock had no problems thereafter. Sounds like you had a defective or poorly installed hub. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
96 F-350 4x4 CC LB, International block and heads from Mcandless IH in Denver, <span style="color: red">Baby Swamps </span>, Luk Cerametallic Clutch, 5" straight exhaust,5 speed ZF, 4.10's, Evolution programmer, Banks brake, non-EBPV IH turbopedestal, AFE Magnum force, CA reg. kit, 12,000 lb. Milemarker on reciever mount, 215amp ambulance alt., 33" muds on factory aluminum, Class 5 bumper hitch, hidden gooseneck, pillar gauges, fosgate amp, 12" sub.
Colorado National Gaurd.
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independece. When Firearms go, all go's. We need them every hour!"
President GEORGE WASHINGTON
bigbore is offline
post #6 of 18 (permalink) Old 11-14-2005, 01:57 PM
Re: lock out hubs
Hum, i had some ford hub that had a plastic red turney thing, and it started to fall apart. I was told it was from ford, maybe they had a cheap version and an expensive version. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
post #7 of 18 (permalink) Old 11-14-2005, 02:37 PM
Re: lock out hubs
Ford hubs ARE made my Warn. They are Warn's lower line. Warn's lower line are 1/4 turn with plastic knob. The Warn Premuim hubs are 9/10's turn and are all metal. Incidentally, I pretty sure that you can only get the premuims for our application.
1996 F350 XL, PSD, CC, LB, SRW, Green/White, 4x4, 4L10, ZF5, LUK clutch & flywheel, 295/75/16 BFG AT on 16 x 8 Centerlines, Bill's Race chip, gutted EBPV, Ceramic coated Hypermax downpipe, Tymar 4" exhaust w/Donaldson muffler, Tymar Intake, Tymar boost pop-off valve, Tymar HX hose, Tymar coolant filter, JD Coolant eye, AC & fuel tank mods, Autometer Pyrometer & Boost gauges in pillar pod, Warn Premium hubs, Powerslot rotors, Smittybilt nerfbars, add-a-leaf & poly bushings, Bilstein shocks, Drawtite front receiver, Optima red tops, 130W Stainless KC Daylighters, stainless Ventshades, Eclipse CD player, MB Quart speakers, JL sub, Phoenix Gold amps, Viper alarm, Cobra CB, 2001 Honda CR250, 400EX & ATC 70 in the bed, not much more to come...
1996CC is offline
post #8 of 18 (permalink) Old 11-14-2005, 03:01 PM
RSP
My Photos: (17)
Re: lock out hubs
Care to explain how you could tear it up that easy? [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
2006 F250 CrewCab Lariat FX4 6.OH AFE, MBRP SS Cool Duals, Elite SCT, 4 Up the pillar, Bed Rug and Retrax Lockable cover.
1997 F350 CrewCab XLT 4x4. ?hp/?lb-ft Intercooled, BTS Trans, BTS Dual HPOP, Big Full Force Diesel Jectors, Big Turbo, Ford AIC, Rockin S Custom 5 inch Exhaust w/AeroTurbine Muffler, AFE Stage II Intake, Total Diesel Performance 4 Positon Chip, White Face Gauges,
1979 F250 SC Lariat 4X4 5.9 CTD, BTS E40D, Dana 60/Sterling 10.25, SD HydroBoost brakes, 440HP 992lb-ft, Intercooled, BFG All Terrains on Eagle Alloy 102s. Custom Rockin S Dual stack Exhaust system. DDP Stage IV injectors, HTB2 Turbo, Snow Water/Meth injection
RSP is offline
post #9 of 18 (permalink) Old 11-14-2005, 03:27 PM
Re: lock out hubs
OK, good info. I never knew Warn had a lower line. Personally I like the 1/4 turn. I replaced the hubs on one of my Jeeps that had the factory jeep lockouts, and the only hubs available were the 1/4 turn Superwinch. I like them a lot better than the Warns on my other Jeeps and they have held up just as well.
I won't go into a lot of detail, but the factory Ford hubs have held up to the driving required in the high CO Rockies getting into and out of remote job sites year round (read deep snow and mud and steep driveways) towing heavy loads of material and equipment and recovery duties for the past 4 years without a hitch. Of the 230,000 on the truck I bet 75,000 were with the hubs locked. If there was a way to break them I would have found it. I serviced them when redoing the WB's and they showed no sign of wear. My only complaint is the stupid snap ring [img]/ubbthreads/images/graemlins/mad.gif[/img].
bigbore is offline
post #10 of 18 (permalink) Old 11-14-2005, 03:29 PM
Re: lock out hubs
Replaced my factory Fords with Warn Premium BEFORE they failed.
Pat
06 F350 4x4 XLT, CC, LB, True Blue, 3.73LS, dash mount Pyro (ESOF knob), with stick, 72K miles, Toyo Open Country MT 275/70/18/E. New Turbo........
97 F350 4x4 XLT, CC, 136k.....SOLD to new owner
GOPDiesel is offline
post #11 of 18 (permalink) Old 11-14-2005, 03:37 PM
Re: lock out hubs
Ebay link
John
FOR SALE*1996*F250*4X4*<font color="red">RED</font>*CC*SB*E4OD*4:10's*4" Exhaust *Tymar*Factory AIC*SnugTop Shell**NAW4*129,XXX miles
KC Fan is offline
post #12 of 18 (permalink) Old 11-14-2005, 04:31 PM
Re: lock out hubs
a bit of off 4X4ing while pulling a load. Apparently it was about to fail. I also think the warns look better on the truck.
post #13 of 18 (permalink) Old 11-14-2005, 04:47 PM Thread Starter
Re: lock out hubs
Can anyone tell me if the standard warn lockouts have the lifetime warranty, or if it's just the premium warn lockouts?
Thanks for all the input
post #14 of 18 (permalink) Old 11-14-2005, 05:36 PM
Re: lock out hubs
Justin,
I would go with the Warn Hubs, they are the best I think I love mine, I got mine from 4 Wheel Parts for about $175. I hated my automatic locking hubs, nice to not get out of the truck but just dont have that truely locked feel.
Good Luck,
Tyler
'96 F350 XLT 4X4 7.3PSD BTS E4OD Amsoil Synthetic Trans Fluid, 109000 miles, Had it since 79000, Reg. Cab Long Bed, 3" Down Pipe, 4" Pipes, 5" Tip, No Muffler and No Kitty, '02 Intercooler, Auto Meter Gauges, Pyro, Trans, Boost, Edge Evolution Programmer, Homemade Tymar Intake, Line-X Bed Liner, Skyjacker 6" Softride Suspension Lift, Warn Manual Locking Hubs, BFG MT/KM 315/75/16
RodsPwrStroke is offline
post #15 of 18 (permalink) Old 11-14-2005, 05:57 PM
Re: lock out hubs
Justin,
I imagine the F350 and F250 hubs are different, but regardless, I would go with the Warn if one or both are bad. Ford's may not be the "top of the line", but they do/did function for the incidental use they were designed to take. Regardless of brand you choose, your better selection will be the aftermarket than the dealership for both quality and price. Another reason most goto International for parts....
Bret
97 F250, 4x4, ext. cab., auto, 4:10LS, Turbo back 4" Stainless Diamons Eye exhaust, Autometer Ultra-Lite gauges, TYMAR intake (the real deal), TS Chip, Dual Tensioner mod, Amsoil Dual Remote By-pass with AMS-Oiler (pre-oiler), Amsoil throughout, D60 swap, and 246K miles (still ticking)
Stong supporter of all US Troops, their families, and all waiting for a safe return. Thank you, from a former soldier and his family
Bret_B is offline
