longer starting time
after diconnecting both batteries to check for the defective battery and then replacing with a new battery, the truck seems to take longer to start. the batteries were left disconnected for about 2 hrs. the starter turns the engine over just fine. it will start after 6-10 revolutions(1 turn of the key). not normal with this truck. this machine used to fire right up. it seems like it's not getting fuel? recently installed a new lift pump, complete fuel housing assembly(minus fuel heater element), a new injector control module(dealer install) and 1,016 miles on oil change(rotella 15w40). do y'all think that the short loss of power affected the computer? thanks for any help.
97 F-350 XLT*7.3L PSD*2X4*BLK*CC*DRW*E4OD*4.10 Gears*Alum. Whls*TYMAR HX mod*Open Air Intake(Tymar copy)*LONG Tru-Cool Trans Cooler #LPD47391*3" DP* Magnaflow 4" S/S exhuast w/5" polished S/S tip*TS-Perf. 6-position chip*Hide-Away Gooseneck hitch*LT235/85R/16*3GA.Pillar Pod/ISSPRO(exh.temp,tranny temp,turbo boost)*Billet Grille*SMITTYBILT Chrome Step-bars*
06' Dodge Ram HD 2500,SLT,4x4,Wht,Quad cab,5.9L CTD,short box,5" Magnaflow exh. w/6"tip,35/12.5-17" BFG A/T M/T,Cool Hose(blk),DTR intake elbow,K&N filter,Dash mounted ISSPRO ga.boost,pyro,tranny),BDTD tuner,Diablo Power Puck,Tuff Country 2.5" lvl kit,Rhino whl-whl step bars,Rhino liner,Defiant steering brace
