Loose Signal Lever...Trying to get clamshell off - Diesel Forum - TheDieselStop.com
Old 05-24-2005, 12:19 PM   #1 (permalink)
PSDfreak's Avatar
I am trying to pull my turn signal lever but I am having a hard time getting to it. I have the front of the steering wheel off (horn, cruise control) and I have the bottom piece off from under the steering column. So far with what I have off, I can get to the lower Torx screw that holds the singal lever on, but the top one is still under the top cover, and I cant get that half of the cover (or clamshell) off cause it looks like it needs to come over the ignition...any help?! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
Old 05-24-2005, 12:26 PM   #2 (permalink)
96P_Stroke4x4's Avatar
Send a message via AIM to 96P_Stroke4x4
Re: Loose Signal Lever...Trying to get clamshell off
pull the key cylinder by inserting something small into the hole under the cylinder... make sure the key is in it so the internal parts dont fly around
Matt
'96 F-250 XLT,x-cab,4x4,BTS E40D,301k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust w/ twin 6" stacks,Tymar,Autometer Lunar Boost,Pyro,and Tranny Temp,white-faced gauges, intercooler,diamond headlights and corners,onboard air,HX mod,Twildman 6-position chip
NRA Life Member
North-South Skirmish Association
"Gotta love the fresh smell of diesel and black powder in the morning!"
2012 VW Passat TDI
96P_Stroke4x4 is offline
