Hi! 97 F-350 I did not like the superchip tuner either. I also used the bully dog chip for awhile which was fine but, the tuner I would recommend is the SCT tuner with custom DP tunes with the tuner you can scan for codes as well as being able to change the shift points also, at which speed it will shift. The tunes that I got was 40T,60T and 60E google DP tuner and give jody a call tell him what you are going to use the truck for and he will recommend which tunes to get also, make sure you tell him about any upgrades that you have done i.e. intake, ,HP injectors, exhaust . Later on down the road if you choose to add upgrades to increase HP you can call DP tuner to change the tunes. I have been using DP tunes now for 4 yrs. and love it. If you do not already have guages it is always recommended to get them when running a chip or tuner to keep an eye on temps EGT, trans, and boost. Good luck! themule
I have a 95 F350 PS/DRW/LB which I bought in 05' with 102,000mi from original owner as of 6/29/12 it has 920,798 mi.on the original engine.It runs great and pulls even better.It pulls commercially anything and everything that pays me money Ha,Ha.Uprades done are an all steel cowl induction hood to help get the heat out of the engine bay,Banks inter-cooler hardware kit using a cooler from a 99 PS,TRUCOOL tranny cooler,Magtech alum.finned tranny and rear diff.covers,DP tunes 40T,60T,60E.S&W guages BST/Trans.Temp/EGT,K&N cold air intake,BD 4"exhaust,HPturbochargers did my upgrades on turbo with banks impeller(a little diff.pitch and height than the stock garrett splitter wheel) and 1.0 exh.for faster spool-up WOW!I'm hoping to hit 1 million miles or more before having to put my drop-in crate engine in.I can only hope that it will be just as good.Hopefully! I can be of assistance to any one needing help with thier PS with problems that I may or may not have encountered.GOOD LUCK!
