Loss of power and hissing sound - Diesel Forum - TheDieselStop.com
Old 06-20-2009, 09:46 PM   #1 (permalink)
Tyler96's Avatar
I have a 1997 powerstroke with about 175,000 miles and it's making a strange hissing sound and has power loss and i just removed the back pressure valve today but its still doing it. please help
Tyler96 is offline
Old 06-20-2009, 09:55 PM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
where is the hissing sound coming from?
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 06-20-2009, 10:04 PM   #3 (permalink)
Tyler96's Avatar
Around the turbo it sounds like. when your driving it sounds like its right under the stick shift or in front.
Tyler96 is offline
Old 06-20-2009, 10:16 PM   #4 (permalink)
STurbo90's Avatar
My Photos: (9)
you may have an exhaust leak from the manifold to the up-pipes causing a loss of exhaust pulses, or the compressor side may have a loose clamp to the intake manifolds,
do you have an intercooler?
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 06-20-2009, 10:18 PM   #5 (permalink)
Tyler96's Avatar
no, the truck is bone stock even the exhaust, i just got it a week ago.
Tyler96 is offline
Old 06-22-2009, 03:50 PM   #6 (permalink)
Question
How did you removed the EBPV? did you gut it?, or just disconneted it?.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
