low beam headlights - Diesel Forum - TheDieselStop.com
Old 01-26-2009, 09:27 PM   #1 (permalink)
EEman's Avatar
low beam headlights
My low beams do not work and when I put my high beams On (high beams do work), the "blue" high beam indicator does not work. Any ideas?
What are the wire colors on the switch that go to the low beams and the high beams?
Thanks.
95 F250 7.3L 4x4 white supercab, 5-speed manual, Tymar intake, new downpipe, cat delete pipe, shimmed fuel regulator, rear air springs, and replaced radio. As of 11/2010, the truck has about 235,000 miles.
EEman is offline
Old 01-26-2009, 11:23 PM   #2 (permalink)
ammayernick's Avatar
Sounds like the turn signal, hi-lo beam, flash to pass, assembly has seen better days. Just had mine replaced after 210,000 miles. Was having same problems(and more as it wears) as you are having.
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps * http://community.webshots.com/user/ammayernick
ammayernick is offline
Old 01-26-2009, 11:30 PM   #3 (permalink)
There's a 40amp fuse in the engine room fuse box, black & orange wire to headlight switch red&yellow to the multifunction sw. red&black to low beam, light green&black to high beam, this was the color code for no DRL, You can email me at my shop @ fsar37@verizon.net if you need more info on the wiring. Hope this helps. rocky
375.0ford is offline
Old 01-27-2009, 07:37 AM   #4 (permalink)
okney1lz's Avatar
Wiring Diagram
See attached pdf
okney1lz is offline
Old 01-27-2009, 08:04 AM   #5 (permalink)
EEman's Avatar
Thanks for the wiring diagram. I do have daytime running lights, but they do not work also. Where is the DRL box located at?
EEman is offline
Old 01-27-2009, 08:05 AM   #6 (permalink)
EEman's Avatar
I have also checked the 40amp fuse, and it is okay.
EEman is offline
Old 01-27-2009, 08:58 AM   #7 (permalink)
The DRL should be behind the drivers side headlight. Its a module that is plugged into the harness.
Bob D is offline
Old 01-27-2009, 10:22 AM   #8 (permalink)
Get a used MultiFunction switch at a junkyard F150,250,350 or Bronco will fit. Have 3 Ford Trucks in the family and I keep a spare in the toolbox, about $20.00
97 F250 Ext Cab E4OD,224K Miles.Mods.10K,Shimmed Fuel Pressure,6637 Air Filter,140Volt IDM, 3" DownPipe.
Jeep1947 is offline
