lower radiator hose issues! - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 01-28-2011, 06:16 PM Thread Starter
somehow my steering stabilizer bar wore a hole in my lower rad hose on my 97 7.3 so i went to ford and they told me NO JOKE buy a new truck! we dont stock it its to old! am i missing something? i could have sworn there is MILLIONS of 7.3l psds out there! and i am sure thats not true! also since i was driving it that way with a pinhole leak i made it home with about 2 gallons left am i ok? or in deep doo doo? its about 50 outside here and it slowly drained out in the bucket i had but since i am putting new in any suggestions while its all out? as far as sca's etc? im wondering if the clunk i am hearing in bumps is a weak shock that made it closer to the hose then normal?
burchbosun is offline
post #2 of 8 (permalink) Old 01-28-2011, 06:24 PM Thread Starter
also what is the easiest way to replace the shocks on this truck? i cant seem to find a wrench thin enough to fit under the tower?
"Tried and true why buy gm when ford will do?"
97 f350 7.3l 321k miles "the old lady"
94 f350 460 190k miles "the tank"
92 f250 4x4 460 195k miles "thunder jaws"'
91 f250 7.3l ats turbo 91k miles "nice n' new"
86 f450 7.3l zf5 hot shot sleeper 170k "The General"
84 oldsmobile cutlass brougham 4.3l v6 220k diesel
83 old 98 royale brougham 5.7l diesel 90k
post #3 of 8 (permalink) Old 01-28-2011, 06:46 PM
bugman's Avatar
My Photos: (12)
First off I would find another dealer. TousleyFordparts list one for your truck but it doesn't have a part number. Also NAPA, AutoZone, O'Rileys, or just about any other auto parts store should be able to take care of you. You can send a PM to Mike R. at TousleyParts who is a member and a sponsor here on the site and he might be able to help you.
As for the shocks I'm guessing that your truck is a 2 wheel drive since I replaced all of mine on a 4x4 in 30 minutes with a 18mm wrench and socket.
bugman is offline
post #4 of 8 (permalink) Old 01-29-2011, 12:51 AM
More likely than a weak shock, would be tired springs. Shocks control spring movement speed, especially on the rebound, they don't actually hold the truck up - springs do. Don't worry, it's a common misperception - somehow people grasp that the springs hold the vehicle up when its not moving, but then think the shock does when the vehicle is moving.
The SCA's should be 2-3 units/gal when you're all filled up.
Bernhardt
Goliath - 94 F350 444DIT CC SRW 4X4 4.10 Luk SMF Coolant Filter 33X12.5R16.5 Reunel Rear Bumper LineX liner Hunter Green 254K
82 VW Pickup 1.6l TD 5sp Gold Metallic 350K
Bernhardt is offline
post #5 of 8 (permalink) Old 01-29-2011, 11:43 PM
pjwoolw's Avatar
My Photos: (5)
Hard to believe an employee of a Ford dealer would actually say that. But stranger things have happened. I hate to think what i would have done. Probably jail time would have been involved.
The Motorcraft part number is 8286 (KM-2990).
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
post #6 of 8 (permalink) Old 01-30-2011, 02:10 AM Thread Starter
i agree
unfortunatly this for employee did and this dealer has cost me money a good few times like removing an entire engine for a rear main when a transmission would have worked and been more cost effective(thanks to learning that AFTERwards when i purchased All Data) and they also tried to say that for a recall only parts are covered for a cps (which the ford letter CLEARED me on )
post #7 of 8 (permalink) Old 01-30-2011, 02:33 AM
pjwoolw's Avatar
My Photos: (5)
What a drag. I'd be on a letter writing campaign. I very rarely visit a dealer for parts. But when I do I call before hand to see if my guy is there and only talk to him. There is one guy I call Vin. No clue what is real name is. He won't even talk about a part without your VIN number.
Pete in San Ramon
pjwoolw is offline
post #8 of 8 (permalink) Old 01-30-2011, 08:08 AM
Stan96's Avatar
no offense, but it sounds like they can see you coming from a mile away.
1996 F-350 XLT 4x4, e4od, Electronic-rustproofing, Viper alarm
2004, @32k mi. glowplugs, drag-link, Michlelin's, waterpump
2010, @76k mi. Ball joints, u-joints, rotors
2011, @86k mi. glowplugs, drag-link, trany fluid
2012, @94k mi. Bilsteins, stainless brakelines, fuelbowl, lift pump, waterpump, steering lines, coolant filter
2012, @98k mi. Starter, positive cables, batteries
2013, @104kmi 3"downpipe, Michlelin's, steering damper, rotors, rear diff oil
2014, @115kmi. Injector o-rings, alternator rebuild
Stan96 is offline
