Marvel Mystery oil ?? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 06-02-2006, 12:43 PM Thread Starter
I tried the search function, but no results.
So, now that I can't find the Diesel Kleen Power Service at Walmart due to the 2007 emmisions, can I use Marvel Mystery instead? What would be the recommended dose to add to a tank of fuel to get at least the minimal proper effect of lube for the pump and injectors?
<font color="blue">_____________________________________ _____________</font>
, Auto, 83K, 4x4, 4:10's, 285-75R-16 "E" BFG K/O's (siped). FPR shimmed, 10K mod, Rancho 9000's.
, and
2005 SnowRiver 8'10", Loaded + EU2000i.
2005 8.5'x16' Interstate West Cargo trailer, Line-X'ed
2005 16' Fish-Rite Rogue welded aluminum boat, w/windshield, full top, sides and back drop. 2005 40HP Yamaha 2-stroke O/B.
INSAYN is offline
post #2 of 12 (permalink) Old 06-02-2006, 12:50 PM
v_lombardi's Avatar
My Photos: (18)
Re: Marvel Mystery oil ??
i use the stp stuff in the light blue jug
vince
1996 F-350 auto XLT CC SRW 4x4 off road. Hypermax dp, Hayden aux elect fan, 285/75-16 BFG at's, factory ford locking hubs, 6,900#'s empty.
Integrity: Steadfast adherence to a strict moral or ethical code.
v_lombardi is offline
post #3 of 12 (permalink) Old 06-02-2006, 02:43 PM
Might consider Lucas Fuel Suppliment, works on both gas and diesel.
PS
'95 F250, 4x4, Open Air Element, Wildman 6-pos custom chip (PCM TEE5), shimmed fuel regulator, ceramic coated 3" DP, removed EBPV, isspro gauges, E40D, 4:10 rear end, Tymar HPX, 4" catless exhaust, turbo boost relief valve, 203 T-Stat, Magnafine tranny filter, Tru-Cool 4590, js idm mod, 175k, DIY Idle controller, Baby Swamps
snowplus_rmk is offline
post #4 of 12 (permalink) Old 06-02-2006, 05:40 PM
"What would be the recommended dose to add to a tank of fuel to get at least the minimal proper effect of lube for the pump and injectors"
0 Oz.
Regular diesel fuel as it comes out of the pump has EVERYTHING in it you need.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
post #5 of 12 (permalink) Old 06-02-2006, 07:04 PM
The fact that they call it "Mystery" oil is your first clue. Just stick with diesel fuel, ignition key, and right foot.
2008 F-250 Lariat, Supercab, Long bed, 4x4, 5.4L non-diesel
Bassman349 is offline
post #6 of 12 (permalink) Old 06-02-2006, 07:42 PM Thread Starter
I was under the understanding that Walmart pulled the Power Service off the shelf due to the upcoming 2007 Emissions requirements for the new Diesels in 2007. Something about it not being emission compliant or something? Kinda stupid if that is the case, as they still sell lead additive for older motors, and would kill the emmisions test on a newer car just the same.
I have not found a local distributor for Stanadyne stuff, so I was going to try MMO, as it says it lubes the HPoil pump, and injectors. Are ya saying that this won't do anything for me? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
INSAYN
, and
INSAYN is offline
post #7 of 12 (permalink) Old 06-02-2006, 09:48 PM
There was a post on this subject several days ago. It was pulled due to a relabeling for the new engine spec's. If I remember it correctly one member said that "they said by June 06 all would be in stock". [img]/ubbthreads/images/graemlins/grin.gif[/img]
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 212k mi.
Currently also have 2012 Dodge 4X4 with a Cummins engine.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
post #8 of 12 (permalink) Old 06-02-2006, 09:58 PM Thread Starter
Excellent! I will take back the 2 gallons of MMO I just bought and trade it for the Power Service. I have to go back to Walmart anyways to get a few cases of Rotella T (gallon). They only had the gallon jugs individually and that seemed a bit more spendy per.
Got a nice long road trip from Oreegun to N'brasky for a big Truck Camper Rally. Then up through S-Dakota, over through Wyom'n, up to Montana, and down to Yellerstone. Then up to Coeur d'Alene Idaho through Spokane, and back down to Oreegun.
Should be a hoot!
INSAYN
, and
INSAYN is offline
post #9 of 12 (permalink) Old 06-03-2006, 03:00 AM
hheynow's Avatar
I'd never use Marvel Mystery Oil because it's dyed red as is off-road #2. I'd hate to be dipped and have to do a lot of un-necessary explaining. Since I'm using ASTM B-100, the new reformulated fuel is a non issue for me.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
post #10 of 12 (permalink) Old 06-03-2006, 06:47 AM
"I have not found a local distributor for Stanadyne stuff, so I was going to try MMO, as it says it lubes the HPoil pump, and injectors. Are ya saying that this won't do anything for me?"
Yes... that is EXACT ALLY what I am saying. While those supplements DO actually add a lube agent, regular diesel fuel already has it. Back a LONG time ago, some fuels were refined different &amp; you had to add things to them depending on what you used them for. Today ANY fuel you get out of a pump at a service station will have EVERYTHING you need to run todays engines. Thats why Ford recommends you DON'T use additives.
Leader is offline
post #11 of 12 (permalink) Old 06-05-2006, 07:55 AM Thread Starter
So the low sulphur stuff coming out soon will be sufficient as well?
INSAYN
, and
INSAYN is offline
post #12 of 12 (permalink) Old 06-05-2006, 09:04 AM
Send a message via AIM to rockets10510
thats what i was wondering. i just took a trip west and not being aroud to drive my truck i didnt notice the lovely sitckers at the pump that say low sulfer disel. i was worried about puting tha stuff in my idi. but i had no choice. so will this stuff be good for our trucks or if now what can we do?
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
