Misfire need help - Diesel Forum - TheDieselStop.com
Old 11-21-2012, 05:31 AM   #1 (permalink)
Misfire need help
I have a misfire on a t444e. The truck starts acting up after it has been warmed up and ran for a bit. It does not happen at any specific rpm or under load, it just gets progressively worse as you drive. Sometimes will even stall. I changed the fuel pump and filters, but that did not help one bit. Any suggestions?
ryandude1 is offline   Reply With Quote
Old 11-21-2012, 09:26 AM   #2 (permalink)
Paul H's Avatar
My Photos: (10)
You may have a bad O-ring on the HPR or have a weak HPOP. When the engine warms the oil gets thinner and can sneek past a weak O-ring.
Plug into it with a diagnostic tool or laptop with software and look at the IPC pressure it may be dropping off
Paul H
OWNER
2004 Ford F350 6.0L Dualie 246.000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty EGR delete running ELC all stock
1996 Ford F350 7.3L Dualie 340,000 Tony Wildman custom burn,5 inch stacks, good ole girl(in Avatar)
1995 Ford F250 7.3L Regular Cab 255,000 miles Sled Puller
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
http://www.fokisd.org/FICM.html
My Pictures
Paul H is offline   Reply With Quote
Old 11-21-2012, 01:24 PM   #3 (permalink)
Misfire need help
Thanks paul. I will take a look. I will keep you posted!
