I recently had injectors replaced, injector harness and injector cups replaced. increased power ran good for only 3 days. lost tremdous amount power, low oil pressure, checked oil level, needed 2gal. ran good for 3miles and gave out. checked oil level did not mark on the dipstick. checked fuel filter,diesel very dark. replaced fuel filter, no change. checked fuel tank seems motor oil is in the fuel tank. any suggestions?
97 international t444e Rollback tow truck
If your talking about the truck in your signature then it's a powerstroke and not an IDI. Hopefully the mods will move it to the right forum. Sounds to me like the seals at the injectors are leaking.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
You need to contact the moderators, cause the engine is a powerstroke. You'll have a much bigger audience and a better chance at the correct diagnosis.
The T444E uses high-pressure engine oil to build the necessary pressure to inject the fuel. If that oil is leaking inside the injector pump you'd see a loss of power because the necessary pressure isn't building up. Plus, the leaking oil could mix with return fuel and end up in the tank.
Phil
1988 F350, NA 7.3l, 5-speed, crew cab, 4.10 SRW. Miles: over 450K. Being taken off the road within the next month or so to deal with advanced rust. May just do a resto/rebuild to better my bodywork & paint skills.
You also could have injector O-rings failed (with the low miles if this is the problem it is bad installation).
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
T444E's do not have an injector pump. They do have a HPOP. A leak in a HPOP can not mix with fuel. Pretty much the only way oil can get into the fuel is a bad injector o ring.
If you had the injectors replaced at a repair shop, they should go good for them.
Sorry about the bad advice to the OP, we had the same thing happen to one of our fuel trucks at work (T444E 4700) and when I asked was told that's what had happened (I didn't work on it for that problem but was curious in case it ever happened again.)
Phil
