My 1996 E350 Van 7.3L has 620,000 plus miles on it from the previous two owners - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 04:10 AM   #1 (permalink)
midwestconnection's Avatar
I should have posted this in 94 to 97 General 7.3L discussion rather than upgrades and aftermarket. Sorry about that. I will move it to General now.
I want to use Rotella T 5-40 Full Synthetic oil in it but I'm afraid.
It is parked outside at -20 below to -40 below and -70 and -80 below with the wind chill here in Detroit Lakes, Minnesota.
It gets almost as cold as Fairbanks, Alaska but not as long a winter and not quite as cold.
I just ordered a 2000 Watt Kim Hotstart for the block drain to heater hose to go along with the factory 1000 Watt block heater and I am also getting battery heaters for both batteries and putting 300 Watt Magnet heaters on the motor oil pan and automatic transmission oil pan.
I also want to put full synthetic gear oil in the rear end.
It's got 620,000 miles on it and you would swear it had less that 100,000 miles on it.
Everything is perfect.
I won't tell you I got it for $850 or actually $700 and $150 to get it 200 miles home.
It's never pulled anything.
It was a bus to haul passengers to the airport in Nebraska, 600 miles a day for the first seven years of it's life and well taken care of by the second owner who put less that 75,000 miles on it the last seven years.
I also need to know what kind of antifreeze to put in it.
Everything is immaculate and I am doing a full service for the winter on it.
It's getting 10 ply 245 75 16 Blizzak W965 Winter Tires next week and I'm putting 1000# of sand bags in the rear of the van. 14x70#each.
Any comments would be well appreciated.
Thank You, Tom
midwestconnection is offline
Old 11-02-2009, 04:29 AM   #2 (permalink)
Window&Door's Avatar
...Wouldn't know much about it, coldest it gets here is 50* Congratulations on the purchase though, someone here will inform you as to what you need for your diesel
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
Old 11-02-2009, 04:41 AM   #3 (permalink)
Thanks, I found the "stickies" too. Great help. Great Forum.
Old 11-06-2009, 06:19 AM   #4 (permalink)
"Any comments would be well appreciated"
what color is it?
scootdog is offline
Old 11-06-2009, 07:55 AM   #5 (permalink)
Toreador Red Clearcoat Metallic and it's almost mint, like the day it was new, which I find to be "unbelievable" here in Minnesota where they salt the roads in the winter. It was in Nebraska the first seven years of it's life.
