Is my transfer case a Borg Warner 1356 ? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 11-05-2007, 11:27 AM Thread Starter
DIESELDUTTON's Avatar
Hey guys, I believe my transfer case is a BW 1356,I did some research for the front yoke and I believe that they have used that transfer case in the 250 and 350 from 86 or 87, I'm still trying to locate a yoke for my double cardan drive shaft and need to know if the splines are the same from 97 250 to a 97 350, I would assume they are the same but you know what happens when you assume [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] Thanks
Frank
2004 Pitbull Motorsports rigid chopper...Traded on 2010 F-250 5/30/14
121 TP 130rwh 250 avon
04 CRF250 mine....Gone
02 CR80 sons...Gone
03 XR100 daughters..Gone
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyone
2011 Cougar 325 SRX Toyhauler
2010 F-250 4 door 6.4 with all the fixins
DIESELDUTTON is offline
post #2 of 3 (permalink) Old 11-05-2007, 11:30 AM
My Photos: (10)
Re: Is my transfer case a Borg Warner 1356 ?
Frank. Still trying to locate the one I told you about. But it is a state over, and I can't get a solid line on it for another minute or two. If I understand correctly, I thought the 97s had a BW-4407 transfer case. I didn't believe it either so I took a look at mine and found the tag.
Kurt
SOLD!!
1997 F350 XL PowerStroke 4WD, ZF-5 w/ South Bend Con OFE Clutch
Regular Cab, Long Bed, SRW, 3L55's, Bilstein shocks, Warn premium hubs
3-inch downpipe/4 inch exhaust w/ Magnaflow muffler and cat
Tymar intake
International Water Pump with integrated filter
Wildman Four-Position Chip; Baby Swamps; D66 turbo with 1.00 housing; SD HPOP
Isspro EV Boost and Pyrometer gauges
285/75R16 E-Rated BFG All Terrain KO's
Rear Disc Brakes from Blackbirds Custom Trucks
spaceballs is offline
post #3 of 3 (permalink) Old 11-05-2007, 11:42 AM Thread Starter
Thanks Kurt, I just looked at the tag on my TC and it says, J2571 4407-04 2417 20 FGTA-SA so you are correct it is BW 4407, now I wonder if it is the same as the 99 SD because the guy that I found who is going to lenghthen the drive shaft had a 99 SD TC on the ground, and the yoke looked to me like it was the proper one for my double cardan style shaft I just wasnt sure of the spline count on mine. Kurt, do you have any idea what size and type of thread for the large fuel plug on the back of the head is ? I know the one that broke on you was 1\8npt, I would love to buy a kit from Bean, but I dont have the extra cash and my fuel pump is leaking AGAIN, I have the filters, I just need to get everything else. Thanks Kurt
Frank
02 CR80 sons...Gone
425 Polaris magnum
