Need flywheel and presure plate torque specs - Diesel Forum - TheDieselStop.com
Old 05-26-2007, 05:24 PM   #1 (permalink)
my stupid DMF bit the dust last night. i got a new luk clutch and everything. i need the flywheel bolts and presure plate specs.
THANKS!
1996 F-250 PSD XL single cab. homebrew intake with napa 6637, 3" DP and test pipe, Luk clutch!
reason for truck: 91 toyota rockcrawler, 36's, lockers F&R, dual transfer cases, rolled and rashed!
chrisjeep7 is offline   Reply With Quote
Old 05-26-2007, 06:20 PM   #2 (permalink)
Re: Need flywheel and presure plate torque specs
I used the specs that came in the clutch box, seems it was 90-100 ft lbs on the flywheel and 25 on the pressure plate.
Dwayne
95 F250 regular cab 2WD. LUK Clutch conversion.
baknblack is offline   Reply With Quote
Old 05-26-2007, 08:33 PM   #3 (permalink)
My Photos: (11)
Be SURE to use some locktite on the flywheel bolts.
1995 F-350 DRW Supercab 7.3 Turbo 5spd
Mozz is offline   Reply With Quote
Old 05-26-2007, 08:37 PM   #4 (permalink)
My Photos: (11)
Also, I assume that you are putting in a new Throwout bearing. Make sure that the collar that it slides on doesnt have any burs, nicks, or flat spots. You can polish it with some really fine sandpaper, something in the 600 grit range. Also be sure to use the proper grease and lube the collar and lube the throwout bearing really good. You may need a new clutch fork, depends on if yours has alot of wear but with that many miles it probably would be a good idea.
Old 05-27-2007, 01:41 PM   #5 (permalink)
thanks, i have put more than a few clutches in. i will take you advice though.
anyone have the specs?
Old 05-27-2007, 03:38 PM   #6 (permalink)
My Photos: (11)
Flwheel - 89 Lbs
Pressure plate - 20 -29 Lbs. I think most people would get closer to 29 lbs.
Old 05-29-2007, 11:03 AM   #7 (permalink)
got the new luk clutch in. dang that would DMF was shot, its like driving a new truck. i would recomend it to anyone, just wish is was not so $$$$.
only took about 4 hours to do. not a hard job at all however, i did have a lift and tranny jack [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
