Need help quickly, broke the radiator overflow nipple off..... - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 11-02-2005, 09:43 PM Thread Starter
I was being dumb and was messing around underneath the hood a put a little too much weight on the radiator overflow line going to the coolant tank. Well low and behold, I broke the plastic nipple that comes out of the radiator to hook the line too. Will it get me to work in the morning and how much coolant will I loose if any? Is this thing repairable? Any cheap ideas on how to repair this permanently?
Thanks for the help
2002 F-350 Crew cab with the 7.3, auto, 4x4, Viper remote start, DP Tuner, brand new Cooper ATRs.
Sold, but missed dearly: 1995 F-250 7.3 standard cab 4x4 with lots of dents. Just a mean wood hauling machine!
brylande is offline
post #2 of 8 (permalink) Old 11-02-2005, 10:03 PM
4door96's Avatar
Re: Need help quickly, broke the radiator overflow nipple off.....
a radiator shop should be able to replace just one of the tanks, we usually replace them for $85 out of the truck.
1996 f350 2wd dulley, 7.3psd, 205k, 5 speed, 3" down pipe,5" exhaust pipe no restrictions, edge evolution programmer, stage 1 injectors, k&n air, and gauges.
4door96 is offline
post #3 of 8 (permalink) Old 11-03-2005, 11:57 AM
Some have used various methods of tapping the hole, installing brass nipple, and JB welding in place. Search the archives, this has been covered frequently.
1996 F350 XL, PSD, CC, LB, SRW, Green/White, 4x4, 4L10, ZF5, LUK clutch & flywheel, 295/75/16 BFG AT on 16 x 8 Centerlines, Bill's Race chip, gutted EBPV, Ceramic coated Hypermax downpipe, Tymar 4" exhaust w/Donaldson muffler, Tymar Intake, Tymar boost pop-off valve, Tymar HX hose, Tymar coolant filter, JD Coolant eye, AC & fuel tank mods, Autometer Pyrometer & Boost gauges in pillar pod, Warn Premium hubs, Powerslot rotors, Smittybilt nerfbars, add-a-leaf & poly bushings, Bilstein shocks, Drawtite front receiver, Optima red tops, 130W Stainless KC Daylighters, stainless Ventshades, Eclipse CD player, MB Quart speakers, JL sub, Phoenix Gold amps, Viper alarm, Cobra CB, 2001 Honda CR250, 400EX & ATC 70 in the bed, not much more to come...
1996CC is offline
post #4 of 8 (permalink) Old 11-03-2005, 02:20 PM
as 1996 said--use 1/8 pipe X 3/8 hose barb---tap tank--screw nipple in with jb weld around it
94_turbo is offline
post #5 of 8 (permalink) Old 11-03-2005, 07:52 PM
KentuckyDiesel's Avatar
My Photos: (63)
That's what I did. -phillip
1995 F350 CC DRW XLT, Converted to 4x4 with D60 front, Alcoa Classics, Large syncro ZF5 tranny with fluid cooler and pump, SuperDuty electric fuel pump, Aeromotive fuel pressure regulator, Davco/Detroit Diesel fuel filter assembly with twin 10 micron Cummins OTR style filters, Stanadyne Fuel heater, Superduty VC harnesses, Tymar intake, Isspro EV Pyro and boost gauges, Autometer pod, Ford AIC, Techonsha Hydraulic brake control, TS 6position chip, JD coolant eye, 4" DP with 5" Auto-Jet muffler and exhaust out the back, SWAMPED.
1997 F350 CC XLT 4x4 Auto tranny. Hypermax gauges, chip, intercooler, DP, and 4" straight exhaust.
1984 F250 4x4-6.9 diesel with a Western plow...Bone stock-about to be restored.
KentuckyDiesel is offline
post #6 of 8 (permalink) Old 11-03-2005, 09:27 PM
If you go with the new tank top they have a brass nipple.
95 250 SC 4x4 auto 4:10 28,000 long cooler shimmed guages pipe WD chip, manual hubs, camper, 22' 5'er horse trailer
Rick Thielmann is offline
post #7 of 8 (permalink) Old 11-04-2005, 09:39 AM
CalFireCapt's Avatar
I had the same problem about a year ago during a waterpump replacement. I squared off the broken nipple and then drilled the hole in the radiator the exact size as the nipple. I inserted the nipple into the hole and JB welded in place. I had to have a quick fix and it has held ever since! No leaks no problems! [img]/ubbthreads/images/graemlins/cool.gif[/img]
If it leaks in the future I'll go with the brass fitting.
99 PSD, F250SD Super Cab, 4X, 6-Speed, Draw Tight Remov-a-ball gooseneck ball, headache rack, Pioneer, the rest is stock.
CalFireCapt is offline
post #8 of 8 (permalink) Old 11-04-2005, 09:47 AM
When mine broke, I super glued it back in place, then put 2-3 coats of JB weld around it. Been there 2 years and never had a problem.
kb
Pinesman is offline
