NEED HELP truck has no power on acceleration???? - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 01-25-2012, 10:42 AM Thread Starter
Over the last thee days my 1996 5 speed has been losing power quick. when driving and taking off. When on the highway if I hit a hill going 50 ill be going 40 at the top but pushing 2500 rpms. My truck barely wants to move now. Sounds fine no rough idle. I have a real bad pedestal oil leak so I'm thinking that the oil just worked into the tranny finally and is making it slip bad? All I know is when I can put my truck in third and let out on the clutch and it idles fine that's not a good thing haha. in case it matters its a southbend 1200ft. Lb. Clutch with a single mass flywheel.
boostjunkie22 is offline
post #2 of 2 (permalink) Old 01-25-2012, 11:03 AM
Sounds like your clutch plate is TOTALLY soaked in oil from your pedistal leak. There's NOTHING in a ZF 5-spd that can slip so it has to be your clutch.
You need to pull the transmission, fix your oil leak, clean the flywheel & pressure plate with Brake-Clean, and install a new clutch disc.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
