new engine rough idle - Diesel Forum - TheDieselStop.com
Old 05-28-2009, 11:41 AM   #1 (permalink)
hi i just put a new engine in my truck while i had transmission out the old engine had cylinder 2 low compression so i installed new engine transfered over my 8 month old stg 1 160 cc injectors truck runs amazing except at idle warm it has cylinder 4 and 5 contribution codes so i swapped injectors from 2 and 3 to see if it was a faulty injector 3 days later still the same issue pulled compression on all cylinders all are great ( should be with new engine ) n accordance to pin point tests there is no electrical issue that can cause this but i call bs now why would it idle rough intermittently i have only 500km on new motor helppppp
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 06-02-2009, 09:25 PM   #2 (permalink)
any ideas
drford is offline
