Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 11-04-2009, 09:02 PM   #16 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
The sensor circled in green is you ICP (Injection Control Pressure) Sensor. It should not be leaking through the connector. Have you tried unplugging it? Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 11-04-2009, 10:20 PM   #17 (permalink)
Parky66's Avatar
My Photos: (5)
Hi Patrick,
No I did not unplug it, will it start unplugged?
Dang... I'm sure learning way too much on this endeavor !!!
Mike Parker - Parky66
1996 F-250 Ext Cab
Long Bed, 4X4, 7.3 PSD
(ZF5) 5-Speed Transmission
(Twildman's) 4 Position Chip
Auto Meter Cobalt Series Gauges on Full A-Pillar
Tymar Intake
(DPP) 3" Downpipe
(DPP) Catalytic Converter Delete Pipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-05-2009, 07:49 AM   #18 (permalink)
Yes it will start with the ICP unplugged. The computer will go to default mode.This monitors the high pressure oil. You can do a 10k mod by adding a resistor to trick the computer into thinking oil pressure is low and it will increase the HPO
97 F250 Ext Cab E4OD,224K Miles.Mods.10K,Shimmed Fuel Pressure,6637 Air Filter,140Volt IDM, 3" DownPipe, lost the kitty.
Jeep1947 is offline
Old 11-05-2009, 05:21 PM   #19 (permalink)
Parky66's Avatar
My Photos: (5)
Today's adventures... and the saga continues....
I unplugged the ICP Sensor and gave her a good cranking, no start.
As far as it being oily as I first suggested, that might have been me when
I was using my allen wrench as a HPOP dipstick. I most likely dripped some
oil on there, I have got it all cleaned up and no further oil has been spotted
yet <fingers crossed>. I cleaned the connector on the passenger side of the
fuel bowl and gave her another good cranking, no start. Next I tried to get the bottom steel fuel line further in the GPR. I'm only abut 1/4" shy from being all the way in to the lip on the steel line. It seems this line got tweaked somewhere along the line of the fuel pump swap. When I was dbl checking the FPR Screen assembly I had to finagle a bit to get the 2 10mm bolts to line up. Not sure if this would cause the no start or not? I will be checking the FPR Pressure tomorrow...
Once again, thanks for all the help
1996 F-250 Ext Cab
Tymar Intake
(DPP) 3" Downpipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-05-2009, 09:34 PM   #20 (permalink)
pjwoolw's Avatar
My Photos: (5)
Check your fuses. Number 22 ? I think will cause a no start.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 XLT 4X4 Gone but not forgotten
pjwoolw is offline
Old 11-05-2009, 09:58 PM   #21 (permalink)
Parky66's Avatar
My Photos: (5)
Hi Pete,
I dbl checked the fuses under the hood again this afternoon. #22 the big "MAXI-FUSE" and all the others look good as well. I just know it's going to wind up being something totally simple after all this fuss...
Thanks for the suggestion...
1996 F-250 Ext Cab
Tymar Intake
(DPP) 3" Downpipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-06-2009, 07:37 PM   #22 (permalink)
Parky66's Avatar
My Photos: (5)
*** UPDATE ***
She's running again... Better than ever !!!
My first full day off in a week, so I decide to start dissembling
and "back track" my way through everything. I pulled the fuel
bowl back off and was going through the wiring yet again. I
decided to pull off the old tape on any connections and look
for problems there. Sure enough... there is a lower connector
on the HPOP circled in orange. I un-tape the old stiff dried up
tape and there was my problem circled in green, one of the wires
that were hacked for some reason had pulled apart under the old
tape. Just hiding there to DRIVE ME NUT'S !!!
I checked and re-taped everything just to make sure there
were no more hide & seeking going on. Got everything back
together and said a little prayer before cranking again...
YES !!!
I would like to thank everyone that helped my through all of
this... you all are truly first class !!!
Hopefully this thread will help others out there with the No Start's.
1996 F-250 Ext Cab
Tymar Intake
(DPP) 3" Downpipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-06-2009, 08:57 PM   #23 (permalink)
Supporting Member
bugman's Avatar
My Photos: (16)
Glad that you found it. Sometimes it is the inadvertent problem that just happened while you are doing something that is the hardest to find.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is online now
Old 11-06-2009, 08:59 PM   #24 (permalink)
pjwoolw's Avatar
My Photos: (5)
Good to see your up and running. Gotta love the PO on that one. Definitely a head scratcher.
Pete in San Ramon
pjwoolw is offline
Old 11-06-2009, 11:12 PM   #25 (permalink)
My Photos: (18)
That was the connector for the IPR. Cheers!
Old 11-07-2009, 07:52 AM   #26 (permalink)
Parky66's Avatar
My Photos: (5)
Thanks for the identification Patrick. The next time you suggest to check the wiring I'll be more throughout the first time fer sure !!!
Thanks again for the help... it's sure is Great having my baby back !!!
1996 F-250 Ext Cab
Tymar Intake
(DPP) 3" Downpipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-08-2009, 10:37 AM   #27 (permalink)
Originally Posted by Parky66 View Post
*** UPDATE ***
YES !!!
Congrats on getting your rig back up and running.
I'm having the same issues with my no-start, but I didn't change out my fuel pump.. just the starter.. it ran yesterday for a while after I installed the new starter, and then died at idle once I got it back home.
So in your pic above, the orange-circled connector goes to the IRP and the green-circled connector is the unplugged connector that you pulled up to take a picture of?
I'm assuming the connector in the bottom right (purple top) is the ICP?
I'm going to double check all the wires as I keep getting 0340, and 0472 codes (changed the CPS yesterday)..
Let's hope today is a better day than yesterday for my truck.
Randy Wheeler
1997 F350 4x4 Crew Cab PSD Lb
Rockdog97 is offline
Old 11-08-2009, 11:38 AM   #28 (permalink)
My Photos: (18)
Yes, the purple-topped one id the ICP. Cheers!
Old 11-08-2009, 12:11 PM   #29 (permalink)
I found this connector (red-circled) that is loose and seems to rock back and fourth (left to right)... is this normal? Is this the same connector as the IRP? (orange circled in previous post?)
Randy Wheeler
Old 11-08-2009, 02:32 PM   #30 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
Those are the HPOP lines off the pump. If they aren't spraying oil everywhere then they aren't the problem.
97 F-350,4X4, CC, LWB, PSD, 251k, K&N, 10K MOD
speeddemon31176 is offline
