New Fuel Pump... no start ??? - Page 3 - Diesel Forum - TheDieselStop.com
Old 11-08-2009, 02:36 PM   #31 (permalink)
no, it's the connector with the light shining on it (between and below the hoses). I tried moving this connector back and fourth while the wife cranked the engine, but still no start.
is it supposed to move?
Randy Wheeler
1997 F350 4x4 Crew Cab PSD Lb
Rockdog97 is offline
Old 11-08-2009, 03:03 PM   #32 (permalink)
Mine wiggles side to side just a little bit. It should not move front to back on the shaft it sits on. Look out on the end of it, toward the fuel bowl side, and see if the nut for that IPR is still there. They have been known to vibrate off and fall in the valley. Also have your checked #9 and #22 fuses? I would assume you have if you've read through this thread.
97 F250 HD 7.3L 4x4 165,000 Mods: 6637 Filter, Poly front bushings, 3" Downpipe, Lost Kitty
brooksbronco17 is offline
Old 11-08-2009, 03:17 PM   #33 (permalink)
thanks brooks.. it does not move front/back, only side to side.
yes, I've checked the fuses as well.
as for not starting, would any air coming in from say the top of the fuel filter cause it not to start? it's a new filter, but could it be leaking???
I'm just about at my wits end on this. I've checked lines, wires, etc, and they seem to be in good condition..
i do have a chip installed and it's set to "tow safe" mode, should I reset it to factory and try starting again?
Randy Wheeler
Old 11-08-2009, 05:55 PM   #34 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
I would suggest uninstalling the chip and see what happens. If it works then it was a free fix. Who's chip do you have installed?
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 11-08-2009, 05:59 PM   #35 (permalink)
Are you getting any smoke when cranking? Can you check fuel pressure with a tire guage to see if your building enough pressure? There is a shrader valve on the bowl to check pressure. Have you checked the level in the HPOP reservoir? should be close to the top of the plug.
Old 11-08-2009, 06:03 PM   #36 (permalink)
no smoke when cranking. HPOP full, and fuel squirts out of the schraider valve. have not checked the pressue.
It's a Superchip - was installed on the rig when i bought it.
Randy Wheeler
Old 11-08-2009, 06:08 PM   #37 (permalink)
Is the tach moving when cranking? Might take a closer look at the wiring to your CPS maybe a broken wire inside the insulation.
Old 11-08-2009, 07:12 PM   #38 (permalink)
yes, the tach moves. I'm not getting any smoke out the tailpipe when cranking.
reset the chip to "stock" but still no ignition.
Randy Wheeler
Old 11-08-2009, 07:46 PM   #39 (permalink)
Get a cheap tire pressure guage and check the pressure on the bowl. After enough cranking I think you should see white smoke. Getting toward the end of my limited knowledge on these things. Some sensor testing might be in your future. A scanner would help to see what the PCM is seeing. Would taking the battery cables off to reset the PCM help any?
Old 11-09-2009, 11:29 PM   #40 (permalink)
Parky66's Avatar
My Photos: (5)
Yeah, that worth a shot...
The only other thing I can add is to
re-check all the wiring take off/replace any old tape and give a good look and clean all the connectors with some good spray electrical cleaner.
Mike Parker - Parky66
1996 F-250 Ext Cab
Long Bed, 4X4, 7.3 PSD
(ZF5) 5-Speed Transmission
(Twildman's) 4 Position Chip
Auto Meter Cobalt Series Gauges on Full A-Pillar
Tymar Intake
(DPP) 3" Downpipe
(DPP) Catalytic Converter Delete Pipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
