New Luk SMFW strange rumble sound? - Diesel Forum - TheDieselStop.com
Old 10-27-2009, 05:11 PM   #1 (permalink)
I just replaced my stock dual-mass flywheel, clutch, T.O. bearing, and clutch fork with a Luk single mass flywheel / clutch kit.
It all went together well. I also rebuilt my clutch pedal assembly. Everything feels like new now.
When I drive at low speed I now hear a rumble sound. It reminds me of driving with knobby tires on a hard surface. I also have the feeling that it sounds like dry bearings - like I was driving with a dry transmission or bad wheel bearings.
I've read some posts where people described the Luk SMFW as being noisier at lower speeds. Perhaps that is all it is, however, I really don't understand how / why it should sound any different... unless I've done something wrong!
Everyone's input is appreciated!
1995 F250 4x4 Turbo Diesel regular cab, 5" exhaust, 6-pos ATS
getrolfed is offline
Old 10-27-2009, 05:27 PM   #2 (permalink)
It takes some getting used to. I just did mine as well and can tell ya wait till you hook onto a load and you'll see noisy. If it goes away at higher speeds I wouldn't worry.
woodman55 is offline
Old 10-27-2009, 05:35 PM   #3 (permalink)
Excavator's Avatar
My Photos: (11)
YEP, my 97 with luk does the same thing
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
Old 10-27-2009, 09:38 PM   #4 (permalink)
Does anyone know what causes the sound? It really sounds bad... like the new clutch/flywheel is soon going to be old!
Old 10-28-2009, 05:20 AM   #5 (permalink)
I think its just gear noise.Mine does the same thing at low rpm.40K on the clutch and no problems(knock on wood).
97 F-250 PSD 4wd 5spd 4.10 SCLB, D60, Tymar intake, 3"dp, EBPV gut, Boost/Pyro gauges, SBC Con-O, Stancor 586-902 GPR, Royal Purple gear and tranny oils
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
Old 10-28-2009, 07:23 AM   #6 (permalink)
I drove one that had the luk and it was very noisy. Luk has a great reputation for durability so I wouldn't worry about it. I ordered mine from napa which is a rebadged valeo, not that I wanted the valeo it's just napa had it the next day. I must say that the valeo is much much quieter than the luk is but thus far can't say it's gonna last forever but am very happy with it. As I said though I do tree work and am constantly pulling a dump trailer with 10 ton and the low gear noise is very evident at that point but empty it is no different than the dmfw was. In addition to the noise the smfw revealed a syncro going out in 2nd gear that was barely noticable before.
Old 10-28-2009, 08:13 AM   #7 (permalink)
Excavator's Avatar
My Photos: (11)
more post on the LUK clutch noise here Loud Gear Noise On Decel???? LUK clutch installed
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 10-28-2009, 10:11 AM   #8 (permalink)
My Photos: (60)
Mine has had the same thing for three years and somewhere around 50,000 miles give or take. My only complaint is clutch chatter when slipping the clutch backing a trailer, otherwise an excellent choice. Light years ahead of that idiotic dual mass factory weirdness.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 10-29-2009, 05:12 PM   #9 (permalink)
i have loved the LUK in my 90 idi for about 45k now pretty soon you wont notice it (the moan). only thing i wanted to add is if your running 36s or taller with 4.10 gears or higher be sure to use low range if backing up hill with a loaded trailer 12k+. I cooked my first disk just being an idiot.
navistar90 is offline
